Installing Gauges
Old Apr 14, 2003 | 08:46 PM
TNabb's Avatar
Installing Gauges
I want to install an A/F guage in my car. Is there any special sensor or anything that I need to hook it up?
Thomas
Old Apr 14, 2003 | 10:16 PM
J-Rat's Avatar
Alcohol Fueled!
You can run a single wire one right off the 02 sensor. Not exactly the best reading, but it should give you a good idea what your car is doing.
Jarrett
Old Apr 14, 2003 | 10:51 PM
silverrotor's Avatar
Run all 3 wires from the A/F Ratio Gauge directly from your ECU using 3 way connectors. I wish I could find a pic to Illustrate...
Old Apr 14, 2003 | 11:02 PM
marcus219's Avatar
FC Mobsta
Running them to the ECU itself, will that yield a more accurate or stable reading? The ECU is just getting input form the 02, does it translate or average it?
-Marc
Old Apr 15, 2003 | 03:57 PM
marcus219's Avatar
FC Mobsta
bump
Old Apr 15, 2003 | 04:29 PM
plz do explain more i am also gonna hook mine up i wanted to know the best way aswell
Old Apr 15, 2003 | 04:38 PM
Yes, IMO. You will bypass the shielded wire leading to the O2 Sensor. At the ECU, It doesn't have this.
Old Apr 15, 2003 | 04:43 PM
Power came from the very top left wire for my A/F Ratio Gauge as did my S-AFC.
Old Apr 15, 2003 | 08:55 PM
marcus219's Avatar
FC Mobsta
more insight...
thanks silverrotor
Old Apr 15, 2003 | 09:49 PM
-Marc
I opted to tap Into the ECU for 3 reasons.
1. I didn't want to disturb the copper sheilded wiring found at the direct end of the wire leading to the O2 Sensor.
2. I wanted to stay away from the heat emitted from my engine.
3. I wanted a neat Installation that allowed me to use 3 way connnectors.
Old Apr 15, 2003 | 09:53 PM
marcus219's Avatar
FC Mobsta
make sense to me
Old Apr 26, 2003 | 07:46 PM
Snufelupogus's Avatar
Do I Really Exist?
do you have to get power and ground it to the wires at the ecu?
cant you use power from something else? say... the fuel pump? and ground it to a bolt on the chassis?
I dont get the difference...
Thanks
Old Apr 26, 2003 | 08:21 PM
Sure you can. Again, I used It their b'c of accessibilty.
andyvideopro
Aug 20, 2015 10:55 AM
LMBTG
Aug 15, 2015 01:43 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
