OMP disabling and oil premix set it straight
hey all
i have been reading through the 2nd gen archives and seeing the LONG write up on premixing im still confused so can someone lay them straight for me? like:
1.in an 86 rotary the tank is a 16 gal so how much 2 stroke oil is need?
2. what kind of 2 stroke oil is best?
3. what type of OMP does the 86 have?
4. how do i disable it?
1) if you want something around a 100:1 ratio, and you're putting 16 gal in the tank, use 20 oz. of premix (1.25 oz per gal- 1.28 oz per gal would be exactly 100:1)
2) General consensus is any two-stroke oil with the TCW3 rating (for good dispersion in the fuel, and ash content)
3) Mechanical- the entire external OMP system is easily removable with the TB/ upper intake manifold off. You will need 4 bolts to plug the oil metering nozzle locations (available at Mazdatrix), and a block-off plate for the metering pump location
4) see #3
4) see #3
Re: OMP disabling and oil premix set it straight
Originally posted by capn
hey all
hey all
2. anything that's labeled TCW-3 (Valvoline Multi Purpose 2 Stroke)
3. mechanical (another good thing about S4...you can just yank it off)
4. either put a block plate on it or remove intake manifold and install 4 bolts to replace the oil injectors
(don't ask what size threads..been too long ago)
I'm seriously doubting if my omp is working on my rebuild.
I think I am going to go striaight premix from now on and just leave the dead omp on.
I've heard that if you put a block off plate on you need to shim it with a dime or something. Not sure why though.
You still haven't got that thing running right, Digi7ech?, LOL...Two dimes work well- they're to keep the drive gear from "slopping" around in there...When I did the rebuild, I just left the block-off plate & dimes alone, but removed the drive shaft from inside the front cover- I'm hoping the dimes are still in place, ha ha...
The car started up on it's own this weekend but I got a Vac leak which kills it off if under 2k rpm.
I was pulling 15hg at 1500 but now it's 10hg so I am going to find it this weekend.
I've put 8 miles on the engine in actual driving so far.
Trending Topics
