any advantages to premix and keeping the omp?
Old Oct 25, 2004 | 10:16 PM
hondahater's Avatar
spending too much money..
Did a couple of searches and found minimal input on this. What do you guys think??? My oil is so clear that you can't see it on the dip stick unless you look closely so I know my mop is working ok but I would also like to premix if it would help anything out. THe reason I'm not going completely premix is because I'm about as abscent minded as they come and would forget to premix one time and blow my engine up. So anyways some good input would be great! Thanks.
Old Oct 25, 2004 | 10:26 PM
hondahater's Avatar
ttt
Old Oct 25, 2004 | 10:56 PM
hondahater's Avatar
oh thats right, premix is something you do to toaster ovens when they start making the toast to dry! For some reason i was thinking it was something we did to our cars.
Old Oct 25, 2004 | 10:59 PM
I wish I was driving!
Better lubrication, still get the carbon build-up. Not as good as straight premix, but better than just the MOP.
Old Oct 25, 2004 | 11:02 PM
hondahater's Avatar
thanks thats what I was thinking. Hey the reason I was thinking about doing this is because I have my turbo off right now and found that when I put my fingers in the exhaust ports to touch the rotors they have a rough surface is this normal or should it be smooth??? Thanks.
Old Oct 25, 2004 | 11:04 PM
Normal. Thats carbon build-up (there's a lot of it, hey? normal). It'll likely get smooth right near the apex seals.
Old Oct 25, 2004 | 11:20 PM
hondahater's Avatar
so with carbon build up being bad is there a way to take it off without going into the engine??? I've heard of using water to clean the rotors is there anything else???
Old Oct 25, 2004 | 11:22 PM
DerangedHermit's Avatar
Hondahater, you should know better than this. Do a search .
Old Oct 25, 2004 | 11:26 PM
hondahater's Avatar
lol I should know this but I'm just considering myself a little bit better than a newb on anything else other than the internals of the engine and electrical.
Old Oct 25, 2004 | 11:27 PM
sar's Avatar
sar
Doin a rebuild.
I'm assuming that stuff like guaranteed to pass emissions, sea foam, and other extremely heavy detergents would help our engines like they do piston engines.
Somebody mentioned lubricated carb cleaner or something instead of water, but I believe everybody thought that could take away some lube and hurt the engine and its not tested.
So, uh, water works, redlining should helps, detergents should help.....
I don't know too much about going all premix, or think i really want to try, but on s5s... can u just like unplug the omp.... or what about removing vacuum lines. If its easy I don't see much problem with trying it, afterall, it might clean it out.
Old Oct 25, 2004 | 11:32 PM
hondahater's Avatar
s4's are easy to remove because its all mechanical witch is also good because they are very reliable however the s5's are electric so you have to remove it and block it off but still keep it wired up so that it won't through a code and put your car in limp mode. Also since they are electric they tend to go out more than the s4's.
Old Oct 25, 2004 | 11:35 PM
Not really, no.
Using a bottle of good fuel system cleaner every tank helps.
Nothing will remove this hardened carbon.
Old Oct 25, 2004 | 11:38 PM
casio's Avatar
casio isn't here.
i'm told the first rotaries didnt even have oil injection (hrmm, when was unleaded fuel a requirement?). if this is true, i'm sure your engine wouldn't "blow up" from a few forgetful tanks. i can't promise this, but its what i'm gathering.
on that note, i planned to make a decal for my gas tank; something like "Premixed Gas ONLY" or something. if that doesnt remind you, you're not absent minded, you're retarded.
Old Oct 25, 2004 | 11:51 PM
sar's Avatar
sar
Doin a rebuild.
This is just a crazy idea, but is there a way to jump the omp connection so it won't throw a code? It would make sense that you could just add some resistance and complete a circuit and fool a silly computer.
Old Oct 25, 2004 | 11:53 PM
hondahater's Avatar
lol, funny **** man! But yes that is a damn good idea! a nice little white sticker (black paint) on the door would work perfect, and this is why I love this site! great ideas! oh yeah and scathcart would it be bad to run premix, omp, and injector cleaner all at the same time
Old Oct 26, 2004 | 12:37 AM
You can do something like leaving the OMP on there but disconnected the oil lines. Dunno, something along those lines. S5 people around?
Just put a sticker on your gas cap that says "Feed Me Oil".
Old Oct 26, 2004 | 10:16 AM
Aaron Cake's Avatar
Engine, Not Motor
This has been covered thousands of times before, and there is certainly more then "minimal" input available. Check the archives. I should close this thread.
Old Oct 26, 2004 | 11:14 AM
hondahater's Avatar
ewwww damn sorry aaron cake but I didn't see anything, I'll search again!
Old Oct 26, 2004 | 11:25 AM
Syonyk's Avatar
Cripes, there's a 30 page long "Premix" thread right near the top of the archives, or just search for "premix" - you'll be reading for days.
As for putting premix in, I haven't had any problems forgetting. Annoying my passenger, yes, but forgetting, no. It feels weird to put gas in my other car now (without premix)... like I'm forgetting something.
-=Russ=-
Old Oct 26, 2004 | 11:33 AM
hondahater's Avatar
lol, I'm sure it just takes getting use to but damn like I said I'd forget and blow something up. Anyways my question was about premix and using the mop wich I didn't see covered to many times.
Old Oct 26, 2004 | 11:36 AM
Do a search for "premix". You'll get about 30489309489394 threads.
Old Oct 26, 2004 | 11:40 AM
hondahater's Avatar
I know, I know enough about premix to know how to premix an s5 and I have an s4. I've read every thread on premixing just nothing comes up about premixing while you still have the mop and if that is good or not. How much to use etc... I WANT TO PREMIX AND USE MY MOP, IS THIS GOOD??? maybe yall see what I"m saying now, lol..
Old Oct 26, 2004 | 11:47 AM
Syonyk's Avatar
The general consensus that I've seen:
If you just want added protection, a 400:1 mix is good if the MOP is still operating. However, if the MOP fails, 400:1 isn't going to help keep things running for terribly long.
The main complaint about the stock oil injection system is the massive carbon buildup it creates. Premixing on top of it doesn't help reduce carbon any.
You can get adapter plates that use the MOP and instead of drawing from the crankcase draw from a separate tank that you fill with 2-stroke oil. This is sort of a "Best of both worlds" - no premixing in the gas tank, but still burning an oil designed to be burned.
-=Russ=-
Old Oct 26, 2004 | 11:57 AM
hondahater's Avatar
wow, where would you get that at???
Old Oct 26, 2004 | 11:58 AM
gerbraldy's Avatar
wtf's a piston
One advantage of premix is you get your engined oil'd immediately when you start your car.
