My dyno chart from this weekend.
Old Aug 4, 2003 | 08:46 PM
1FastT2's Avatar
For everyone who hasnt seen it in the single turbo section.
Heres the specs of the run.
-15psi
-94 octane pump fuel
-8.5:1 rotors
-TO4B 60-1, P trim, 0.84 tang exhaust housing
-85deg and almost %100 humidity (very hot out!)
Overall im pretty please with the 405hp but was disapointed with the torque. Im thinking it had alot to do with the weather. Let me know what you think.
Thanks,
Brian
Old Aug 4, 2003 | 09:51 PM
turbo-rotary's Avatar
Not too bad.
Old Aug 4, 2003 | 10:38 PM
BLUE TII's Avatar
Rotary Motoring
Awsome HP!
Is that corrected for a turbo? If not, yes that weather would have quite an affect (standard correction is for NA and weather affects them MUCH less).
Nice #s, Ian
Glad it never gets over 65 deg here...
Old Aug 5, 2003 | 12:32 AM
Turblown's Avatar
Turn up the boost
Those are good #s
Rotary Performance Parts
Old Aug 5, 2003 | 12:33 AM
Turblown's Avatar
Turn up the boost
Those are good #s, stock ports?
Old Aug 5, 2003 | 12:39 AM
Project84's Avatar
Open up! Search Warrant!
Very nice. Whats the a/r trim, 1.15?
Old Aug 5, 2003 | 01:05 AM
Project84's Avatar
Any idea what the rear wheel HP and Tq is? It says flywheel graph at the very top in small print.
Old Aug 5, 2003 | 06:07 AM
1FastT2's Avatar
Originally posted by BLUE TII
Awsome HP!
Nice #s, Ian
Im not sure what the correction factor was at.
1FastT2's Avatar
No, I have a pretty big street port.
Old Aug 5, 2003 | 06:09 AM
1FastT2's Avatar
Those #'s are wheel HP and TQ readings.
Old Aug 5, 2003 | 07:12 AM
Ryde _Or_Die's Avatar
Is that as high as your going to go? I'd love to see it turned up to like 20psi
Old Aug 5, 2003 | 07:28 AM
1FastT2's Avatar
Nope, im going to keep adding boost and tweak the tuning till Im right about at 20psi. The run was just to see what my car would do with pump gas.
Old Aug 5, 2003 | 08:57 AM
projekt's Avatar
smaller ports would up your torque, as would more pressure. remember torque = displacement.
Old Aug 5, 2003 | 09:06 AM
fastrotaries's Avatar
W. TX chirpin Monkey
was the turbo chocking up top, hence the large margin between the two. I don't know the specs, so i'm just guessing.
Old Aug 5, 2003 | 09:14 AM
1FastT2's Avatar
There were no signs that the turbo was choking at all. The specs are in the 1st post.
Old Aug 5, 2003 | 10:59 AM
$150FC's Avatar
Currently Winning
I fear your turbo lag, as your setup is a lot like mine :P
Great HP, but what's up with the Torque? Even with the weather I would have expected ~315ish, at least that high up in the revs.
Have you thought about going to maybe 8500 rpm? It doesn't look like your power is dropping off at all. The torque peaks at ~7000 or 7500, but since your torque figures are kinda out of wack to begin with for whatever reason, they may peak a little higher, too.
Check your PMs a little later tonight, too. I've got some questions for you.
Old Aug 5, 2003 | 11:07 AM
eViLRotor's Avatar
Brother of the Rotary
With a .84 A/R turbine, he shouldn't be lagging too much at all
Old Aug 5, 2003 | 11:36 AM
West TX RX-7's Avatar
Da Monee Pit
Nice numbers but your right the torque looks a bit low. Have you ever run on that dyno before?
Old Aug 5, 2003 | 12:03 PM
OPEC's Avatar
Nice numbers.. I hope to get mine up there sometime in the near future. But first I have to change out some parts.
Old Aug 5, 2003 | 12:20 PM
Turbo Timmy's Avatar
Professional Lurker
That's wild how it jumps 30hp in the last 800 rpm...
Old Aug 5, 2003 | 01:39 PM
BDC's Avatar
BDC
BDC Motorsports
It might be you've got the primary ports too large which will kill the mid-range a bit. The turbo itself is setup pretty well although I would vote for going to a larger hotside.
Good horsepower; the torque is shy about 50ft/lbs of where it should be.
B
Old Aug 5, 2003 | 02:17 PM
RETed's Avatar
How big are the exhaust ports?&nbsp If the exhaust port has been moved extensively up or down, this'll kill torque.&nbsp Early exit of the exhaust gases decreases the time the combustion charge can "work" on the "crank" (or e-shaft) - very early opening of the exhaust port causes drastic drops in torque.
For example, I run a very early opening exhaust port (almost 1" lower than stock), which killed my torque numbers.&nbsp My car dyno'd 253.9hp at the wheels, but only making 207lb-ft of torque on that particular run.&nbsp I run these very large exhaust ports for top end power only.&nbsp For a broader power band (i.e. keep torque high), I wouldn't port the exhuast port as heavily...
-Ted
Old Aug 5, 2003 | 02:47 PM
1FastT2's Avatar
-Ted
My exhaust ports open approx 3/8" earlier then a stock port but close at the same as stock.
Old Aug 5, 2003 | 08:41 PM
1nastyturboII's Avatar
pretty decent numbers
Old Aug 5, 2003 | 08:42 PM
RETed's Avatar
Hmmm...that's not an especially wild port.&nbsp You did a recent compression test?
-Ted
