Correct Oil Temp ???
Old May 30, 2003 | 11:52 PM
madscientistrx7's Avatar
I just completed my full motor swap, single turbo, the whole nine and started it. Within about 20 minutes of idle time I pegged my oil temp gauge at 300 degrees. Does anyone know where it should be?? Any help would be greatly apprecaited. Thanks...
Old May 31, 2003 | 04:30 AM
rynberg's Avatar
You are definitely in trouble if that gauge is reading right. It sounds like the thermostat to your oil cooler(s) is not opening.
My normal oil temps with a single stock cooler range from 190-220 F in daily use. The highest I have ever seen was after the 3rd run on a dyno, where it hit 250 F.
Most guys I've seen with twin oil coolers are running 180-200 F daily use.
Old May 31, 2003 | 09:29 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
It might be a good time for you to look into ungrading your oil cooling system especially if you only have one.
The1Sun
Mar 18, 2018 11:08 PM
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
