Oil Catch Can
For a number of reasons, if there weren't a vent in the oil system, it would pressurize and things would get ugly. Normally, the PCV valve takes care of venting this pressure. It routes the aerated oil that this pressure creats into the intake stream so that it gets burned.
If you remove your emissions system, you end up with either one (N/A) or two (TII) vents coming from the engine that will spew oil all over the place. A catchcan, well, catches this oil and stores it so that you can do with it what you please.
Brandon
Brandon
Well I just bought one from my friend. And technically I don't think its useful for a Rx7 since the engine design is different from pistons which sometimes require them.
I have all my emmissions..and sayign that I install the catch can which hoses should I plug and lead to the catch can?
Cant you just buy those little K&N filters, stick that on the end of a vent line and attach it some where near the bottom, or under the car? Not exactly the most environmentally friendly method I guess. But then again a lot of us arent running cats
Trending Topics
Open up! Search Warrant!
Good questions.
The common oil vent is next to the oil filler neck, down on the intermediate housing. TIIs have an extra one right near the oil filler cap, but that one's not nearly as messy.
A catch can has an open-air vent to relieve pressure at the top, and a drain valve at the bottom, by which it is emptied. The whole idea is that oil added into the intake stream takes the place of fuel and air, and thus reduces hp. So you stop that from happening. Well, and it eliminates complexity. But you also catch the oil in a can so it doesn't make your engine messy. Follow? When the catch can fills up, you just drain it into a drain pan or an empty oil bottle and recycle it. If it overfills, oil spews out the open-air vent at the top, as if you were overfilling any sort of container.
Brandon
Brandon
Mazda loved that damn oil injection **** didn't they? I guess I see the need for it being that the rotary has lots of metal seals on the rotors and the car wouldn't have appealed to as many people if having to remember to use premix was sales point. But I run premix! But why can't the original vents relieve the pressure? Its exposed to the atmosphere, and it is at the highest point of the engine.
Would a oil pan baffel prevent oil from over pressuring and over flowing?
Hmm.. i have never heard of any oil bustin' out from runnin premix. Well, my friend Gabe "Rotorific" has a ******* oil spill in his car, and we cant seem to find out where its at. You guys think its this no catch can ****?
Anyone have a site or pictures that are more specific?
Thanks
Thanks
Ok me and charles just talked about my oil spill it was because of my omp block off plate, ive since then fixed it so disregard what he said hes well uh high -Gabe
troym55
23
May 25, 2016 12:42 PM
Adaptronic Cranking fuel table messed up?
sherff
Sep 12, 2015 12:22 PM
tiger18
Sep 3, 2015 08:27 PM
