n/a engine into Turbo II
Old Nov 1, 2001 | 02:39 AM
ianbell's Avatar
I have the opportunity to buy an 87 turbo II with a re-built turbo and blown engine - body and drive train good - I currently have an 87 n/a with an excellent engine with about 50k but a lot of rust.
Question is how big a job to put my engine into the T2 - will the turbo fit? Is the n/a engine a straight fit on the T2 tranny? [my tranny has bent shift forks - don't ask] - any other weird stuff in the switch I haven't thought off - basically, all I want to do is switch engines, and have a T2 in good shape for a reasonable price.
Old Nov 1, 2001 | 07:20 AM
RussFC's Avatar
Not Practical
Well,
The T-II tranny won't bolt up, but that's not half your problem. You'll need an ECU, and more than that, a wiring harness. You cannot bolt all the factory turbo stuff to your N/A. The motor are way too different. If you were to do this swap, you'd have to use your whole N/A motor. It would definitely not be worth it. IMO
RussFC
Old Nov 1, 2001 | 10:32 AM
tesla042's Avatar
You can take the t2 flywheel off, and put it on the n/a engine... then, it will at least bolt up to the transmission.
-Tesla
Professorpeanutrx7
Aug 15, 2015 01:38 PM
ncds_fc
Aug 15, 2015 10:06 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
