My engine rebuild process
Old Apr 21, 2003 | 07:51 PM
Dvst8's Avatar
Going for the win
I thought I share some of my experience with rebuilding my engine.
here are some pics
my housings seem to look "ok" theres no major grooves and dents, but there is some minor scratching (just enough to catch my nail on it) done by the small apex seal. is this a bad thing?
Can someone define a "usuable" housing?
also Iam going to be replacing my front rotor housing with a spare rear rotor housing (better condition), now i know there was an issue about emmisions, does this apply to:
A. a motor with 2 rear housings
B. a motor with 2 front housings? .
C. a motor with rear and fron switched?
ill get some more pics of the housing soon.
Old Apr 21, 2003 | 08:07 PM
RyosukeTakahashi's Avatar
what the hell is that big triangle thingy???
seriously though, when I was getting my engine rebuilt, the guy (Adam) say that any scars, that you can even feel with your finger nails, its done. needs to be refinised or what not.
Old Apr 21, 2003 | 09:16 PM
spunks's Avatar
Nope you can't refinish a housing,you must replace it with either a good used one or a new one.
Dvst8's Avatar
Going for the win
really? anyone else?
Old Apr 21, 2003 | 09:21 PM
dr0x's Avatar
pei > caek
Small grooves are ok, but if you can catch your nail on it, its toast.
Old Apr 21, 2003 | 09:23 PM
RexRyder's Avatar
well i seen places that do the refinishing on rotor housings, so i guess u can refinish them, or "lap" as i've read. not to sure tho.
Old Apr 21, 2003 | 09:38 PM
well from what I've been told, mazda has a hardening process that they say is removed once you refinish or "lap" them. It would be pretty hard rebuilding engines with only new or good condition housings when considering the fact that many engine failure is due to blown apex seals which end up scaring the housings. Each time that happens less and less housings would be available, but of course that is not the case.
Old Apr 21, 2003 | 10:01 PM
marcus219's Avatar
FC Mobsta
I like your work shop..
Old Apr 21, 2003 | 10:21 PM
Dvst8's Avatar
Going for the win
yeah its got grass in it too.
anyone have any clue about using 2 rear rotors?
Old Apr 21, 2003 | 11:13 PM
Manolis_D's Avatar
Take some pics of the housing scratches -- I'm sure people could tell you if they're ok or not with the pics. I believe you can use 2 rear rotors, but i'm not sure. You oughtta doublecheck
-Manolis
Old Apr 22, 2003 | 12:11 PM
Dvst8's Avatar
Going for the win
some pics of the housings
Old Apr 22, 2003 | 12:41 PM
walterh's Avatar
Front and rear rotor housing are interchangable as long as they are the same series.
Old Apr 22, 2003 | 12:46 PM
Bebesito21's Avatar
all 13b rotor housings are interchangeable
Old Apr 23, 2003 | 01:09 AM
RotaryRevn's Avatar
Interesting, why does it get scarred down the middle anyone? Stock oil injection system?
Old Apr 23, 2003 | 02:04 AM
Dvst8's Avatar
Going for the win
i wonder about that too...but its not as bad as it looks...i can barely notice the "scarring" in the middle with my fingers, no more that approx .001"
Old Apr 23, 2003 | 02:06 AM
Sir Coolness
Looks good, still kind of iffy on your ghetto garage though
Th0m4s
Feb 26, 2019 02:04 AM
