Screw It Want To Go Mechanical.......
anyone having the directions for changing carb to mechanical please help ...........diagrams pictures any thing at this point before i really mess things up!!!!!!!
Just went through this not too long ago...A couple of days actually.
Link to the thread about it:
https://www.rx7club.com/forum/showth...al+secondaries
Link to the directions a friend (82transam) and I made:
http://slegers.com/sites/sean/mechsec.htm
Thanks again Sean for making that.
~T.J.
~T.J.
No problem man. Youll feel some resistance in the pedal, its normal. Im getting used to driving lik this now. Just wait till about 3K-3.5K before you floor it
. Thank Sean for that tip as well
~T.J.
.~T.J.
Trending Topics
is it really worth all the hassle(well it doesn't look to take that long but im a lazy person..) you guys really felt a difference? what do you fell? more power when the secondaries open? that shuld be around what 4000-5000RPM? and what is this "flatspot"? on my stock 12A engine, all the power comes in after bout 4000RPM... is that when the secondaries open?
thanks
thanks
Originally posted by Adsy01
ummm no it isent
ummm no it isent
rex79: yea, its more than worth it to do this mod. IMO
so they open ONLY when you floor it? would it be better for them to open when you just press on the pedal? because if they don't open because I'm not flooring it... there isn't going to be a power loss right? because normally they kick at at about 4000RPM no?
They open when the pedal is like 3/4 of the way down. You will feel some resistance than they open and you get a rush of power and acceleration. And yes, the car will still have the same amount of power when driving normally.
Rex79 - If you drive normally with this mod, it actually increases your gas mileage a little. I used to get around 300 miles per tank; now I get around 360.
After you switch to mechanical, you're going to have to learn how to drive the car without bogging the carb down with air, since there is no AP on the secondaries. What I do is smoothly press the pedal down until I have the secondaries open a little and then floor it if needed. If you floor it from a stand still, the car will stall; too much air and too little fuel. It takes time for the pressure to drop enough so that the fuel will compensate for the larger amount of air flow.
.~T.J.
Originally posted by RotorMotorDriver
Holy ****! I only get 200 in the city!! My Dads GSL-SE gets 300, but a 12A getting 300? You must do a lot of highway driving
~T.J.
.~T.J.
Thank you RotorMotorDriver, i switched to mechanical last night. Holy ****!!!! What a difference!!!
I wanted to do this mod a while ago, but was not sure exactly how to do it. The pics were a BIG help!
But, i do have 1 question. In the last pic where you say tie the 2 linkages together.
I was wondering if i tied the right 2 linkages?
The 2 i tied together both move at the same time anyways, i don't understand why i would have to tie them together
If/when you have a pic of the links tied, could you let me know cause i will only have the net until Nov 29th, and i want to have this done before i move.
Thank you again!
Vince
P.S. For the people who haven't done this yet........DO IT!
Thank you again!
Vince
