Question about high/low imp injectors.
Old Jan 21, 2002 | 10:00 PM
TonyTurboII's Avatar
Glock Lover
Ok, heres the question. TO my understanding, all yellow injectors are low imp, and red are high imp right? They changed the imp in 88, so some cars have low, and some have high. I have some spare red-topped injectors that came with my j-spec, and was wondering if they would work in a 88 that uses red topped injectors. I want to make sure they will, cause I dont want to sell injectors to someone who cant use them.
Old Jan 21, 2002 | 10:07 PM
Six Rotors's Avatar
Forget the colours(heat and age changes them anyway),just measure the resistance:
1-3ohms =low impedance;12-16ohms=high impedance
Old Jan 21, 2002 | 10:15 PM
Glock Lover
Ok, but I dont want the person im selling them to have to rip apart their intake to check the resistance. Its easy for me cause theyre out of the car.
Old Jan 21, 2002 | 10:28 PM
Felix Wankel's Avatar
Super Newbie
I believe the tab for the connector is off centered on the low impedance ones.
Old Jan 21, 2002 | 10:30 PM
Glock Lover
God damnit why cant this be easy.
Old Jan 21, 2002 | 10:44 PM
Super Newbie
All you have to do is look at the connector and see where the raised tab is. It is easy.
Old Jan 21, 2002 | 10:57 PM
Boosting_FC's Avatar
I believe that the high impedance injectors had round connectors. The low injectors should have square connectors. Jay
____________
Sorry my bad...See Mazdaspeed post below. If it oval, for sure it high impedance.
Old Jan 21, 2002 | 11:00 PM
Super Newbie
All the connectors are square. Just the tabs are different.
Old Jan 21, 2002 | 11:04 PM
mazdaspeed7's Avatar
mad scientist
The S4's had square connectors, the S5 had oval. The impedence switch was in 87, so theres both high and low impedence injectors with the square connector.
Old Jan 21, 2002 | 11:18 PM
Glock Lover
So no color will distinguish?
Old Jan 21, 2002 | 11:22 PM
fc3s.org's Avatar
OG
Yes it will. If they are red, then they are high impedence. If they are purple/brown/yellow (those are all purple but heat aged differently) then they are low impedence. he can also check to see if he has the resistence pack next to the passenger side headlight to see if they are highs or low.
Glock Lover
Better yet, the 88's had high imp?
Old Jan 21, 2002 | 11:23 PM
Glock Lover
He said his were definately red, he has an 88 GTU.
Super Newbie
All the 88s should have high impedance.
Old Jan 21, 2002 | 11:26 PM
mad scientist
You are wrong on the purple. S5(oval connector) 550 cc injectors(TII) are purple. S5 460 cc injectors(n/a) are red
Old Jan 21, 2002 | 11:27 PM
mad scientist
Correct, the impedence switch was mid 87.
Old Jan 21, 2002 | 11:34 PM
Glock Lover
I just tested them, both 12.4 of resistance.
Old Jan 21, 2002 | 11:38 PM
My stock injectors are were (changed them out already) red, oval ones. I think the colors are different and may not represent much...I have heard many people having different color injectors on the same car year/model.
Jay
Old Jan 21, 2002 | 11:40 PM
fc3s.org's Avatar
OG
I have (10) 550cc injectors out of 2.5 S5 motors and they are all red.
Old Jan 21, 2002 | 11:51 PM
mad scientist
I have 8 460 cc injectors out of a 90 GTU and an 89 GTU, and all are red. I have 2 purple 550 cc injectors from an 89 TII. I think color is BAD way to tell the injectors apart.
I must say, between the injectors and wire colors, Mazda needs to stop changing so freaking often. My 90 n/a engine warign harness has some different colored wires than my 89 engine harness. Its completely retarded.
Old Jan 22, 2002 | 12:11 AM
fc3s.org's Avatar
OG
Agreed totally! maybe mine are all heat rinsed so they appear red. LOL I know that they are 550cc and that is all that is important!
I think best way to check impedence is to just measure them. It isn't hard to pull off the upper manifold. Hell, the N/A is even easier than the TII IMHO.
Old Jan 22, 2002 | 07:09 AM
noboost's Avatar
To confuse the issue;
This past weekend I pulled low impedence (2 ohms) red injectors out of my '87 N/A.
I have sent them out to get cleaned. When they come back I will attempt to remember to post their part numbers that are embossed on the side of the injector. Is there a list of injector part numbers that we can use to I.D. injectors? If not, let's start one.
-john
Old Jan 22, 2002 | 09:12 AM
HAILERS's Avatar
HAILERS
Screw colors. They don't hold the color over time. Use part numbers. You've got some high impedence injectors but not a clue whether they are 460 or 550. Got some part numbers? Its right on the side of the injector. Something likea -1350 or -1370
Try this thread and Lars Young: https://www.rx7club.com/forum/showth...threadid=40835
And to assure that you are totally confused, whats to stop someone from taking a 460- and sending it off to RC and having them make it a 550? Then how could you tell? You could flow it yourself into a measured container, I suppose.
_Tones_
May 25, 2021 05:37 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Nosferatu
Sep 5, 2015 02:13 PM
