Injector questions
Injector questions
Hi-I have been trying to find a particular RX7 injector-it comes from early turbo 2 models. I have found four of them-part number 195500-1370-they have a purple top. I also picked another 4 with the exact same part number, and the plug looks the same, although these have a beige top. I was wondering if anyone could tell me the differences between the two-Thanks-Eric
This thread http://www.rx7forum.com/showthread.p...threadid=35524 and the answer by LARSYOUNG. larsyoung
Rotorite
195500-2010 - dunno
195500-1350 - 1986-87 non-turbo 460cc 1.5-3 ohm. Color should be brown
195500-1370 - 1986-87 turbo 550cc 1.5-3 ohm. Color should be purple.
This info came from TSB 033/87
Lars
Rotorite
195500-2010 - dunno
Lars
Thanks-that kinda helps, but at the same time it confuses me more-the injectors I have are both 195500-1370. The purple top one I know are 550's-the light/brown-beige ones I don't know. The injectors appear exactly the same-same black body,same exact top/plug. If anyone can help out-don't hesitate
Thanks all and have a safe holiday season--Eric
Don't know if this helps at all-but here are some pictures I have found on the net of the tan/biege ones
http://www.dreamwater.org/auto/mk3su...exus/lexus.htm
Here is a pic of the purple ones
http://www.supras.com/sogi/techtips/...nfo/index.html
Thanks-
Thanks-
I think you have 550's. Any way, there is a locating tab on them. Is that tab centered or offset from center? Have you ohm'd them out to see if they are low impedence(2-3 ohms) or high impedence,12ohm? Just curious.
I just checked them both and both the purple top ones and the tan ones come in at 2.3x ohms. I know that the purple top ones are 550's for sure. I may just send one of the tan ones out to RC to be flow tested to be 100% sure they are 550's. It just baffles me that they would use two different colors, but the same part number. Both the plugs appear to in center, and they both are exactly the same-Thanks-Eric
Trending Topics
Skeese
65
Mar 28, 2017 03:30 PM
