fuel injectors?
Old Aug 13, 2002 | 02:07 PM
vmb
fuel injectors?
can you run bigger secondary injectors on a 89 turboll
without a s-afc or resistors?
Old Aug 13, 2002 | 02:55 PM
Aaron Cake's Avatar
Engine, Not Motor
Yes. But you will run too rich top end unless you can tune them down. And good luck finding high-impedance high flow injectors.
Old Aug 13, 2002 | 03:23 PM
vmb
what do you recomend running on a 89 turbo ll with a streetported engine
Old Aug 13, 2002 | 03:28 PM
Wankel Traitor
There is no such thing as a high impedence injector over 550cc/min.
You have to tie in resistors to bump the impedence up between 12 and 16 ohms.
For a streetported engine with a full exhaust, get a pair of 720cc's for your secondaries, you should be fine. I would worry about replacing the fuel pump first however. You will probably feel a bit of a stumble when the secondaries come on without a tuned S-AFC.
Jameson
Old Aug 13, 2002 | 04:46 PM
vmb
ive got a 255 walbro pump already
Old Aug 13, 2002 | 04:52 PM
FC Drifter's Avatar
Damaged Little F*cker
the injectors will make a bigger difference than the pump. i got 720s in my car and they are untuned for now. car runs stupid rich and there is a slight stutter when they start flowing. one question i have though. i got an 87 T2, what impedance is my car? the primaries are from an 89 i know that they are prolly wrong for the car. but the secindaries are right im sure of that. i think i need to wire in some stuff to setup the impedance for all the injectors, but im not sure what the impedance for the S4 and S5 cars are.
vmb
how much for the 720 inj and where do i purchase them and the damn resistors
Old Aug 13, 2002 | 05:21 PM
vmb
any write up for the installation ?
Old Aug 13, 2002 | 05:35 PM
HAILERS's Avatar
HAILERS
Go to the wrecking yard and pickup the solenoid resistor for the 86-mid 87 cars. Walla, you now have the proper resistor.
Early 87 had low impedence and guess what the later 87 have. Look for the solenoid resistor under the afm/filter assy. Free download of the factory manual at http://www.iluvmyrx7.com for a look to see what one looks like.
Old Aug 13, 2002 | 05:45 PM
vmb
i read a post that someone tried it and couldnt get it to work .....was he just bs or not smart enough to properly install it?
Old Aug 13, 2002 | 08:55 PM
vmb
Old Aug 13, 2002 | 09:34 PM
pip's Avatar
pip
the blackest incarnation
You have to check the month your car was made in, because halfway through the 87 production they switched to High impedance, I believe it was march, could be wrong(and usually am)
Old Aug 14, 2002 | 01:04 AM
Rpeck's Avatar
What R U thinking self?
You can send your injectors off to get them "oversized" I am getting my high impedence injectors bumped up to 1000cc's costly though ... $178 Each.
Old Aug 14, 2002 | 11:55 AM
HAILERS's Avatar
HAILERS
VMB.....he was not as talented as you. Do it. Easy. Solenoid resistor has one wire to supply the 12v for the injectors and four coming out to the injectors. I'd get a solenoid resistor from the wreckyard and also cut off the plug from the harness that goes to the solenoid resistor so you'll have wires to splice to. Try to cut it off so that you have five or six inches of wire on the plug to splice to.
I think some folk have gone to radioshack and got resistors that did no meet the requirements of the car so to speak. If you swipe the solenoid resistor pack from a 86-87 model, you KNOW you have what is needed.
Old Aug 14, 2002 | 02:00 PM
vmb
aight
Old Aug 14, 2002 | 05:46 PM
vmb
how much and where to get them?
Old Aug 15, 2002 | 10:10 AM
vmb
bump
Old Aug 15, 2002 | 10:15 AM
BoostedRotors's Avatar
I HATE sleepy eyes
Yeah, trying to run resistors is a waste of time (theres 68 cents Ill never get back )Get a resistor pack from a pre 88 car, doesnt matter if its NA or turbo, thats the easiest way.
Old Aug 15, 2002 | 10:22 AM
I HATE sleepy eyes
Price is variable, usually between 50-150 per injector. Id reccomend looking on thepartstrader or the for sale section here on the forum. I got mine off an 84 GSL-SE.
Old Aug 15, 2002 | 11:54 AM
vmb
what size are the gsl-se ?
Old Aug 15, 2002 | 03:13 PM
vmb
Old Aug 15, 2002 | 03:16 PM
Rpeck's Avatar
If it cost that much money per injector for a resistor pack .. hten you still have to buy the injectors... why not do like I am doing and have your current injectors moddified? Less money and WAY less effort.
Old Aug 15, 2002 | 05:16 PM
rotarygod's Avatar
Rotors still spinning
I have a resistor pack from an '87 I don't need if anyone is interested. Just pm me on details.
Old Aug 15, 2002 | 05:19 PM
I HATE sleepy eyes
What? a resistor pack is like 10 bucks. I got mine free...
Old Aug 15, 2002 | 05:47 PM
Rpeck's Avatar
Ahh, I thought you were saying 50-150 for the resistor pack per injector.. it might be a little cheaper to go that route then.
