stock injector sizes
Old Oct 27, 2002 | 08:02 PM
texmirage's Avatar
Newbie
could some one tell me what size injectors 2nd gen use?
n/a and turbo models. If I read the injectors right they are 330cc for the n/a's. I think the turbo's are 550's???
thanks guys,
albert
Old Oct 28, 2002 | 04:04 AM
NZConvertible's Avatar
I'm a boost creep...
For all 86-91 RX-7's:
NA: 4 x 460cc/min
Turbo: 4 x 550cc/min
Old Oct 28, 2002 | 06:46 AM
Evil Aviator's Avatar
Rotorhead
There are two componensts of an injector flow rating:
1) The flow rate
2) The fuel pressure at which this rate occurs
Stock injectors:
NA: 444cc/min @ 34.1psi, 472cc/min @ 39.8psi
TII: 532cc/min @ 34.1psi, 458cc/min @ 39.8psi
If you average these, you will get the slang flow rate given in the previous post. Obviously, lower fuel pressure will yield a lower flow rate, and higher fuel pressure will yield a higher flow rate. Not all fuel injectors are rated at the same pressure, so be sure to do your math.
http://www.rceng.com/technical.htm
Old Oct 31, 2002 | 09:34 AM
SaabGuy's Avatar
This is some good information but I think I see a typo.
Why would the TII have 458cc/min at 40psi?? I think that should be 558cc. Typo.
Old Oct 31, 2002 | 02:05 PM
Scott 89t2's Avatar
SOLD THE RX-7!
yeap typo...
Old Oct 31, 2002 | 06:02 PM
Rotorhead
Actually it should be 568cc/min. Sorry about that. All of this info is in the Factory Service Manual, which has less typos.
Also, (532cc + 568cc) / 2 = 550cc, which is the average flow rate normally assiciated with the TII injectors.
FD7KiD
15
Feb 26, 2021 10:12 PM
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
FD7KiD
Aug 17, 2015 11:50 PM
armans
Aug 15, 2015 09:08 PM
Snook
Aug 15, 2015 08:18 AM
