flex-fans instead of......
Old May 29, 2002 | 09:57 PM
would you recomend a flex-fan instead of the factory fan and fan clutch? if so wich one. Or should i get 1 big electric fan or 2 small ones. everyone tells me flex fans are good to keep the motor cool but sucks out horsepower cause its always on. let me know what you think guys...
Old May 29, 2002 | 10:15 PM
yo ne body got a flex installed??
Old May 29, 2002 | 10:18 PM
I wish I was driving!
WHY??? the stock clutch fan cools the car great! The only reason anyone should ever change it is a failing clutch or to gain some hp with a e-fan.
Keep the stock clutch fan if you want a pulley driven set-up. In functioning order, it is MORE than sufficient, and a flex fan would be a step in the negative direction, IMO.
Sean cathcart
Old May 29, 2002 | 10:26 PM
thanks..
Old May 29, 2002 | 10:47 PM
'Vert in Vegas's Avatar
I agree, If you want to change:
Go Electric.
Do a search for good ideas on this forum,
Old May 29, 2002 | 11:04 PM
Spiderman's Avatar
Newbie
Carrol Smith, the author of "Tune to win" "Prepare to win" and "Build to win" had a discourse on flex fans....
the following is a rehash from memory...
as engine rpms increase, the blades do indeed "flex" flattening out as described, becoming a spinning aerodynamicaly SOLID DISK. So even though you're hauling down the road, the fan blades form an obstruction to air leaving the radiator.
use the stock type fan clutch unless you're goin racing.... then go electric!
Old May 30, 2002 | 12:56 AM
fastrotaries's Avatar
W. TX chirpin Monkey
if the stick fan fails, then i would say go electric if you can afford it. the extra power and room under the hood is nice. If not the stock unit does its job great.
Old May 30, 2002 | 01:02 AM
MtnRacer's Avatar
infini guru
How much of an HP increase by going electric?
Steve
Old May 30, 2002 | 01:04 PM
Steve
Minimal. You won't feel it. But every little bit helps!
Old May 30, 2002 | 04:42 PM
Roy James's Avatar
My cars louder than yours
i kinda felt it on my 88GTU when i went to ele fan, more so just on revs, and the electric fan, depending on the one you get, wont be near as loud or clumbsy as the stock clutch. The room under the hood is just about worth the conversion IMO
Old May 30, 2002 | 05:05 PM
Wormiez's Avatar
Hey Scathhard which Electric fan do you have?
And were in Vancouver did you get hold of an Electric fan?
Old May 30, 2002 | 05:34 PM
I got a black Magic.
Ordered through summitracing.
You can also get them through Lordco. I can get you a discount with them as well.
