egt gauge
Old Sep 10, 2002 | 01:47 AM
rotorbrain's Avatar
fart on a friends head!!!
egt gauge
i was wondering if when you buy an egt gauge it comes with the sensor. if it doesnt where would one find such an item?
paul
Old Sep 10, 2002 | 01:53 AM
FDokinawa's Avatar
Greedy's comes with a heated o2 sensor...
Old Sep 10, 2002 | 02:12 AM
Flyrx7's Avatar
Money Pit
The Defi unit comes with a sensor probe and fittings, but you will have to have your DP modded to hold the bung. The rule of thumb is to put the EGT sensor at half the diameter of your exhaust (=radius) from the mounting flange. So if you have a 3" DP, mount the probe 1-1/2" from the flange, and try not to mount it straight up from the bottom, so crud won't collect on the threads of the probe, etc.
Frank
Old Sep 10, 2002 | 04:09 AM
rotorbrain's Avatar
cool thanks. . . when you say the defi gauge do you mean all the defi gauges? im planning on getting the d-series gauges. thanks, again.
paul
Old Sep 10, 2002 | 05:57 AM
gzon's Avatar
you dont want to put the egt probe in the DP, You should place it in the manifold before the turbine otherwise it will not tell you what you want.
If your runnin NON-SEQ you can put it like this.
Old Sep 10, 2002 | 06:53 AM
apneablue's Avatar
while we are on the topic of EGT can someone explain what that thing is supposed to be reading?
Thanks
Old Sep 10, 2002 | 07:04 AM
Munchy2000's Avatar
Yes, that's my crotch...
Exhaust Gas Temperatures?
Old Sep 10, 2002 | 07:23 AM
apneablue's Avatar
^^^^ Yes, the egt gas temps...what are normal values?
Tanks
Old Sep 10, 2002 | 08:03 AM
rotorbrain's Avatar
Tanks
good question!!!!! does anybody know how hard it would be to put a whole into the hks exhaust manifold?
paul
Old Sep 10, 2002 | 08:30 AM
youngteggo's Avatar
It around 1400-1500 deg F. Mine is running between 1200-1300, which indicates I am running rich. Check ot the following:
http://www.scuderiaciriani.com/rx7/AF_meter.html
Old Sep 10, 2002 | 09:57 AM
duboisr's Avatar
why does a EGT gage come with a heated 02 senser from Greedy?
Old Sep 10, 2002 | 10:07 AM
rotorbrain's Avatar
haha, i was just gonna let that one go.
Old Sep 10, 2002 | 01:24 PM
7-sins's Avatar
thats not paint....
Thats sweet... next time I have my turbos off I will have to do that.
Old Sep 10, 2002 | 01:58 PM
SPOautos's Avatar
Hey, where did my $$$ go?
One thing to consider if you mount it in the exhaust manifold and a part of the tip comes off (which does happen with our very hot exhaust temps) it will destroy a turbo.
If you mount it just past the flange in the dp you dont have to worry about that. I would just stay more conservative with my readings knowing that its really a little hotter than what its showing.
Also, just because your reading is more or less hot doesnt necessarily mean your rich or lean. Timing plays a huge roll in exhaust temps.
STEPHEN
The1Sun
Sep 18, 2015 07:13 PM
kryan9
Sep 15, 2015 10:11 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
