Speedo wire?
Old Jun 5, 2003 | 02:28 AM
owenxguo's Avatar
Speedo wire?
I am gonna install a Greddy Turbo Timer but can not find the speedo wire from ECU.
plz help
thank you!
Old Jun 5, 2003 | 10:02 AM
HAILERS's Avatar
HAILERS
Because there is none.....at the ECU.
Old Jun 5, 2003 | 10:18 AM
Icemark's Avatar
pick it up at the back of the gauge cluster, or the power steering computer (on S4 and Turbo models) or at the cruise control computer.
Hailers is right, there is no speed signal at the ECU.
Old Jun 5, 2003 | 10:22 AM
HAILERS's Avatar
HAILERS
Hailers also didn't give the whole story in his answer. Thank you.
Old Jun 5, 2003 | 11:28 AM
owenxguo's Avatar
so what should I do?
Old Jun 5, 2003 | 01:19 PM
Icemark's Avatar
hook up the Turbo Timer to the speed sensor wire coming from the back of the gauge cluster, or the power steering computer (on S4 and Turbo models) or at the cruise control computer.
Old Jun 5, 2003 | 01:49 PM
HAILERS's Avatar
HAILERS
https://www.rx7club.com/forum/attach...postid=1022159
Old Jun 5, 2003 | 02:02 PM
Scott 89t2's Avatar
SOLD THE RX-7!
just leave it off... and hook the e-brake one up.
Old Jun 5, 2003 | 06:20 PM
Icemark's Avatar
I knew Hailers would post it so I didn't have to go look it up
Old Jun 6, 2003 | 02:47 AM
owenxguo's Avatar
where the wire at? under gauge?
Old Jun 6, 2003 | 10:25 AM
Icemark's Avatar
same color as in that diagram, green/red.
Old Jun 6, 2003 | 12:19 PM
HAILERS's Avatar
HAILERS
If you mean the Cruise Control unit and the Green wire with the red stripe (GR), the CC is located just aft of the fuse box. If you have no cruise control, the plug will still be there awaiting a aftermarket install.
The plug has 13 sockets on it. One of which is GR. It should be in the middle of the plug. That's for a series four. The plug should have a B, LW, GO,Y,G, GW,WG,Br, LR, GR, GY, L, GB colored wires on it.
rgordon1979
40
Mar 15, 2022 12:04 PM
DocHoliday89
Oct 12, 2015 07:42 PM
