Haltech Wierd blip in datalog
Old Aug 28, 2002 | 07:22 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
At high boost levels, I am getting an odd, intermittent misfire, which shows up in the datalog as a 16,000 rpm revs momentarily once, in a single row, then returns back to whatever RPM the engine was turning.
So far everything looks to be in order, and its just at boost over say about 13 psi, but it doesn't do it all the time, I am going to shield some of the wiring with some metallic braid to see if that takes it away,
I am running an MSD6a on the leadings, with new taylor wires, and the plugs are newer as well.
If anyone has seen this before, I would appreciate some insight..Max
Old Aug 28, 2002 | 11:06 PM
Maxthe7man's Avatar
Fixed...Grounded the shielding wire in the haltech Cas Harness..Max
C. Ludwig
Jan 30, 2019 06:31 AM
jibe
Sep 24, 2015 11:38 AM
teebeekay
Sep 16, 2015 01:54 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
TainoIndian
Dec 3, 2001 10:32 AM
