Is this a "safer" spot for an engine torque brace?
Old Aug 10, 2005 | 09:01 PM
7racer's Avatar
Saw this scanning the Japan Yahoo auction site.
Old Aug 10, 2005 | 09:27 PM
HAI-TEK7's Avatar
Thats hot!! how much??
Old Aug 10, 2005 | 09:29 PM
RX7Wishing's Avatar
BOOOYAHHHH!
safer?!?!
Old Aug 10, 2005 | 09:32 PM
HAI-TEK7's Avatar
^^i think he meant in the case of a motor mount failure this set-up would not pull out the inner fender, like the other ones that bolt on other side by ABS.
i like that set up IMO.
Old Aug 10, 2005 | 09:34 PM
c00lduke's Avatar
Better then nothing but how stiff is that alt braket going to be?
Old Aug 10, 2005 | 10:20 PM
7racer's Avatar
I meant by safer as some people had the UIM separate from the lower due to torque from a place that wasn't suppose to have it with the standard engine torque braces out there.
Old Aug 10, 2005 | 11:07 PM
cewrx7r1's Avatar
Eye In The Sky
I never saw or read direct evidence of this, only people worrying about it.
Old Aug 10, 2005 | 11:11 PM
Trout2's Avatar
Looks like it will put all the stress through the alternator bracket, which will probably bend. They are on the right path. If it connected to the front housing where the engine lift hook is located, it would be better.
Jack
Old Aug 11, 2005 | 12:27 AM
7racer's Avatar
https://www.rx7club.com/forum/showth...que+brace+leak
Old Aug 11, 2005 | 02:26 AM
t-von's Avatar
Rotor Head Extreme
Well I have some evidence. A torque brace mounted to the UIM "WILL" put more pressure on the LIM mounting studs and LIM gasket section. Under normal driving conditions you may never experience any problems with that location however, if taken to the strip and violent wheel hop is experienced, the load/unload (think of how an impact wrench works) forces will cause the entire drive train shake. This puts a tremendous amount of stress on the engine mounts, tranny mounts, diff mounts, and the torque brace mounted to the UIM. Since the torque brace is designed to keep the engine from rotating, the forces have to go somewhere. The LIM mounting surface. In my case excessive wheel hop at the strip caused a small leak in my LIM. After the run, I lost a little vacuum and was like WTF. Then I remembered about my torque brace. I then grabbed some carb cleaner and sprayed at the base of my LIM and guess what....the engine stumbled.
Anyways, I really like this new design. I would rather have a damaged alternator bracket than a possible crack/leak in my LIM.
Edit: I just realized that I'm the one that posted that info on the other thread. Car still runs great with the small the leak.
Old Aug 11, 2005 | 08:44 AM
dubulup's Avatar
development
fix your car man...
Old Aug 11, 2005 | 03:26 PM
poss's Avatar
Slower Traffic Keep Right
While it is "safer" than the typical location, that bracket is pretty flimsy for a torque brace. I can't see it effectively doing it's job. On the positive note, it probably has enough flex in it to make NVH negligible.
Why don't people get good motor mounts and be done with it? Or at least make sure that your mounts are in tip-top shape before installing what IMO is a bandaid.
Old Aug 11, 2005 | 10:50 PM
t-von's Avatar
Rotor Head Extreme
Originally Posted by dubulup
fix your car man...
If it aint broke..don't fix it. Besides I'm putting in a 20b soon.
Old Aug 11, 2005 | 10:58 PM
Motor City RX-7's Avatar
how much?
Old Aug 12, 2005 | 12:02 AM
7racer's Avatar
it's kinda a moot point on the cost. I dont think the seller is shipping international. This was from yahoo japan auction site.
Old Aug 12, 2005 | 09:59 AM
FDNewbie's Avatar
Sponsor
This was from my own two eyes (from https://www.rx7club.com/forum/showth...=397032&page=3):
Originally Posted by FDNewbie
THIS JUST IN! I just got a call from my body shop (who works on FDs all day long), they have a local FD there right now w/ a torque brace that broke the mount on the UIM! Obviously, they need a new UIM, as I believe that entire peice is cast iron. I dunno who's car it is, but I'll see if I can find out or snap a few pics if I can get down there anytime soon!
I don't know anything minus that it's broken from a torque brace...apparently it was too much torque, and instead of taking out the fender wall, it took out the UIM mount lol. Go figure.
And yes I know it's cast aluminum
Old Aug 14, 2005 | 03:27 AM
sDylish's Avatar
anyone speaks japanese ???....haha
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
diabolical1
30
Jan 30, 2016 05:50 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
