What octane to run???
Old May 29, 2002 | 10:18 PM
telus.net's Avatar
What octane should be put into a 2nd gen N/A?
Old May 29, 2002 | 10:19 PM
I wish I was driving!
87 octane regular.
should cost you about $.65/L right now.
*wink*
Old May 29, 2002 | 10:24 PM
telus.net's Avatar
is that standard spec ideal octane???
Old May 29, 2002 | 10:27 PM
the cheapest **** you can get here... is more than you need for maximum power.
Old May 30, 2002 | 12:00 AM
Scott 89t2's Avatar
SOLD THE RX-7!
wo you back from the bushes sean?? or did you break into some bonie cabin with a phone line and computer LOL..
Old May 30, 2002 | 01:00 AM
jreynish's Avatar
New Project on the Way...
what about TII with a fat T04 turbo?
Old May 30, 2002 | 01:11 AM
MtnRacer's Avatar
infini guru
That's a joke right? Race gas if you can find it!
Steve
Old May 30, 2002 | 01:36 AM
The Ace's Avatar
Greek Power
NAs dont need too high octanes, unless heavily modified.
Turbos on the other hand need as much octanes as possible, due to the higher temperatures (to avoid detonation). Over here we have 98 Oct, which is "SuperPlus", and now we also have Shell's "V-Power", which is 96 Oct, but also contains various engine cleaning products
Old May 30, 2002 | 02:07 AM
Silkworm's Avatar
Has been.. hangin' around
Liter? What the heck is a liter?
And yes, 87 is fine for NA, 92/94 for a Turbo..
98?!!!!!!!!!!!!!!!
Good grief! I wish!
PaulC
Old May 30, 2002 | 02:31 AM
The Ace's Avatar
Greek Power
98?!!!!!!!!!!!!!!!
Good grief! I wish!
PaulC
Well, 98O is the maximum number of octanes, so it wouldnt be a surprise if it actually had 96 or 95...
Old May 30, 2002 | 09:49 AM
Silkworm's Avatar
For some perspective, here in the People's Republik, we only get 91.
Yes, 91. Yes, tha'ts lower than the MID grade some of you get.
PaulC
Old May 30, 2002 | 09:51 AM
Felix Wankel's Avatar
Super Newbie
Hehe we get 93 and 94 here. To hell with CA
Old May 30, 2002 | 10:40 AM
easy p-cheesy's Avatar
SPORKY
PaulC
yeah.... and we pay MORE than what you guys pay for your 92/94.
I'm gonna hit those jerks on the head with a torque wrench!
Old May 30, 2002 | 11:04 AM
CanadianRX7's Avatar
here get 92 and 94 here in BC
Old May 30, 2002 | 11:49 AM
Silkworm's Avatar
Ok Uncle Daddy
Paul
Old May 30, 2002 | 01:07 PM
Not really. Tore my anterior ligament in my ankle, so WCB gave me three weeks off at 12 hours a day, 6 days a week, $18 an hour (about what I was making working).
I stay at camp, and every day get a ride into Vanderhoof with the camp maintenance guy and then truck back home.
I go to town for physio, but still have 6 or 7 hours to spend around the *city*.
Old May 30, 2002 | 01:19 PM
Forseti's Avatar
Octane
A liter is what everyone in the world uses to measure fluid volume, except for good ol' America.
Most NA owners I've talked to don't seem to find a difference between 87 and higher grades (89,91, 94, 96, 101...etc)
I've found that I do notice performance differences when using 87 over 94. BOTH on my 89 TII and even on my 85 GSL-SE (13B NA EGI).
I also find 94 burns cleaner, and gets me better kpl (mpg).
/F/
Old May 30, 2002 | 01:24 PM
Silkworm's Avatar
Yep, which means that we're right, and everyone else is WRONG!
LOL
PaulC
Old May 30, 2002 | 01:25 PM
Re: Octane
/F/
You should always be using high octane fuel on your TII anyway, and your NA car will run faster on 87 octane fuel.
The "performance difference" with higher octane fuel on your NA is purely psychosomatic.
Old May 30, 2002 | 06:43 PM
Evil Aviator's Avatar
Rotorhead
Re: Re: Octane
Same with the turbo cars. If using the highest octane available in your turbocharged car makes you feel better, then go ahead, but in most cases it's a waste of money. I don't suppose that any of you TII owners have bothered to look up the octane requirements in your owner's manual?
Old May 30, 2002 | 07:10 PM
AE Turbo's Avatar
Speed from skill
Re: Re: Re: Octane
Aren't those minimum requirements?
Seperate octane question: In Japan, they have higer octane fuel correct? So if you buy a J-Spec, shouldn't you have to use a higher octane fuel like 91 with a booster??
Old May 30, 2002 | 08:23 PM
autocrash's Avatar
Now with more 1st Gen!
good question.,.. I hadn't even thought of that... it's prolly another thing mentioned in the owners manual (of the j-spec car... which we don't have... )
Old May 30, 2002 | 10:57 PM
Rotorhead
Re: Re: Re: Re: Octane
Well, you have an 88 AE TII right? Just open up your glove box, flip through the owner's manual, and post what you find.
What does a "minimum" anti-knock requirement mean to you? For example, if 87 is the "minimum" octane required to keep the engine from detonating, what would be gained by using 91 octane? Would 91 yield even less detonation that you didn't have to begin with using the 87? How about 93 octane? Would that allow for even less, less, non-existent detonation than the 91 octane? Where does it end?
First of all, the manufacturer and/or engine tuners determine the specifications for their products, not the petroleum retailers. LOL, like autocrash said, you will need to check the J-spec specs, ask others what works, and/or figure it out for yourself. Secondly, the US uses a different method to determine the octane rating than most other countries, which causes the same fuel to be rated lower in the US. These are the basic types of octane ratings:
RON: Research Octane Number, based on normal engine operating conditions, this is the standard for most countries.
MON: Motor Octane Number, based on higher engine speeds and inlet temperatures, this is usually 6-12 points lower than the RON for the same fuel.
PON: Pump Octane Number, based on the formula (RON+MON)/2, which in English means an average of the two. This is the US standard, and you may have noticed a yellow label on the gas pump listing this formula.
SON: Supercharge Octane Number, which is a dual-rating for aviation fuel. The first rating is based on a supercharged engine at cruise, and the second rating is based on a supercharged engine at boost. The common avgas carries a 100/130 SON rating.
Note that some fuels will have better anti-knock properties under load (MON) than others, despite the fact that they carry the same PON or RON. Also, other factors besides fuel octane rating will affect detonation, such as tuning, engine wear, humidity, altitude, ambient temperature, etc. The bottom line here is to find a fuel brand and grade which works well for your car under the conditions in which you drive it. BTW, for those of you complaining about the fuel differences in the USA, here is a map of the problem:
http://www.exxon.com/exxon_gas/us_fuels_map.pdf
Here is some high-octane consumer info from the US Federal Trade Commission. Warning - do not read if you have been paying extra for super unleaded all these years, LOL.
http://www.ftc.gov/bcp/conline/pubs/autos/octane.htm
Old May 31, 2002 | 12:27 AM
relvinnian's Avatar
We can get 100 unleaded here in Ohio
