QUICK HELP!! NPT and ????
Old May 3, 2002 | 06:19 PM
dre_2ooo's Avatar
I am trying to install a new water temp guage for my S5 NA. I just got the old sender out and the new one WONT GO IN!!
What's this NPT crap!?!!
HOW can i make it fit in right. It seems to fit nicely into the knock sensor hold, so does the stock thermo sender.!!! I can see NO reason why it's not going in!!
QUESTION : does the stock sender work the same way??? can i just hook up the new guage to it and have it work???
THANK FOR ANY HELP
Old May 3, 2002 | 06:21 PM
RETed's Avatar
NPT = National Pipe Thread
It's the standard U.S. thread they used to hook-up pipes.
Your stock sensor is a metric thread.&nbsp Obviously, you've found out, it doesn't fit.
You really need the proper size NPT "tap" to ream the threads out so that your NPT sensor can fit in.
-Ted
Old May 3, 2002 | 06:29 PM
dre_2ooo's Avatar
OK. do you know what tap i need to use on this? It says "-27" on the AFTERMARKET sender.
THANKS
Old May 3, 2002 | 06:34 PM
RETed's Avatar
It sounds like a 1/8"NPT-27.
Any hardware store should have these things - check out the tools section next to the drill bits.
-Ted
Old May 3, 2002 | 06:40 PM
dre_2ooo's Avatar
ok thanks, what do i look for?? a metric conversion?
Thanks RETed, you're a lifesaver
Old May 3, 2002 | 06:42 PM
Kahren's Avatar
i am not a girl
if u dont wanna do anything yourself u can get an adaptter from www.racingbeat.com
Old May 3, 2002 | 06:46 PM
RETed's Avatar
Wait, if this really is a 1/8"NPT-27 fitting, then the threaded end is like 1/4" in diameter?
This thing will NOT fit in the stock water temp sensor hole, if you're talking about the MAIN water thermo sensor in the back of the water pump housing; you need this sensor anyways for the stock ECU.&nbsp You've got the stock water temp sensor for the stock gauge in the side of the engine, but do you really want to disable the stock gauge?&nbsp This means you'll need to drill and tap a hole for the new sensor...
I tend to put aftermarket gauge temp sensors here...&nbsp (The temp sensor is the one with the smaller black wire in the middle of the pic.)
-Ted
Old May 3, 2002 | 06:58 PM
dre_2ooo's Avatar
whoa whoa whoa.
I bought this from tmak26b and he said it fit fine into his engine w/o any kind of adaptation.
It's the hole RIGHT next to the oil pressure sender, a little below the fuel lines. NOT the thermosenor the ECU needs. Single black wire comes from it. tmak said you didnt need to drill any new holes or anything, just swap in the new one. I don't care if the stock guage doesnt work, i want to read the more accurate AutoMeter one
Now i am confused
Old May 3, 2002 | 07:06 PM
RETed's Avatar
Ok, you realize this is going to KILL the stock temp gauge, right?
All you need is some teflon tape...
Put the teflon tape on the sensor threads
CRANK the sensor into the hole as hard as you can
That should work and seal everything up.
Keep in mind, once you do this, you can't put the stock sensor back into the hole...
Does that make any sense?
-Ted
Old May 3, 2002 | 07:10 PM
dre_2ooo's Avatar
Ok i'll try that. Yeah, I don't care about the stock temp guage, i'll probably be the last owner of the car so I can live w/o it .
Old May 3, 2002 | 07:30 PM
dre_2ooo's Avatar
OMG!! WHAT a difference the piping tape made! Put that vynl tape on there and it went right in. Took some hard cranking though, but it's in there. .
Ahhhh.... now all i have left is easy wiring.
RETed, you are the KING of the FC's
Old May 3, 2002 | 07:45 PM
RETed's Avatar
Alright!&nbsp Congrads!
-Ted
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
