Did the FD alternator conversion.
Old Sep 15, 2002 | 04:28 PM
J-Rat's Avatar
Alcohol Fueled!
Spent last night converting the car to an FD alternator. Wasnt too hard, except for widening the spacer...
Old Sep 15, 2002 | 04:39 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Good going, notice any power improvements ?
Old Sep 15, 2002 | 04:45 PM
Got time to do a write up?
That sounds like something I may wanna consider at some point.
Old Sep 15, 2002 | 04:51 PM
J-Rat's Avatar
Alcohol Fueled!
Are you kidding?!?! That thing is the SHIZNIT!!! My fans run better, the car feels better (could just me be), I am really happy about it!
Rpeck's Avatar
What R U thinking self?
Well how's the output? How much has it helped?
Old Sep 15, 2002 | 04:52 PM
J-Rat's Avatar
Alcohol Fueled!
I used this write up to do it...
http://www.geocities.com/rx7_ragtop/alternator.html
Old Sep 15, 2002 | 04:54 PM
MIKE-P-28's Avatar
Sweet!
Old Sep 15, 2002 | 04:55 PM
J-Rat's Avatar
Alcohol Fueled!
I get 14.5 volts at idle, no loads. At idle with E-fans, A/C, rear defroster, headlights, I get about 12.9 Volts. The thing puts out some juice....
Old Sep 15, 2002 | 04:58 PM
J-Rat's Avatar
Alcohol Fueled!
Here is a side shot...
Old Sep 15, 2002 | 05:01 PM
Rpeck's Avatar
What does a FD altinator go for? what brand did you get? Got it new at a parts shop I assume?
Old Sep 15, 2002 | 05:04 PM
J-Rat's Avatar
Alcohol Fueled!
Its a Pro Amp alternator, it was a little spendy, about $160.00. It was a toss up between the $199.00 135 amp that Alterstart makes, or the FD alternator. The FD was less expensive, so I went that route. I wish I could have gotten one used, but they arent easy to find here....
Old Sep 15, 2002 | 06:31 PM
J-Rat's Avatar
Alcohol Fueled!
Just went for a drive, A/C fan blows better, temps stay lower... I HIGHLY reccomend this mod...
Rat
Old Sep 15, 2002 | 06:38 PM
soul assassin's Avatar
GTR eater
now you will have enuff power to run your NAAAAWWWS solenoids and under body neon kit!
Old Sep 15, 2002 | 06:40 PM
J-Rat's Avatar
Alcohol Fueled!
Dont forget my electrical supercharger!
Old Sep 15, 2002 | 06:43 PM
GTR eater
and you can plug your **** annilahtor 2000 ***** in your cigarette lighter and drive with it up your *** now
Old Sep 15, 2002 | 06:46 PM
J-Rat's Avatar
Alcohol Fueled!
LOL!! I forgot about that! It always ran poorly at idle...Its probably gonna rip now!
Old Sep 15, 2002 | 09:26 PM
marlaman's Avatar
Need an E6x
What does one of those run and where can i get one? does it give such improvemtns as Nos stickers or neon kits.
Old Sep 15, 2002 | 10:07 PM
J-Rat's Avatar
Alcohol Fueled!
Old Sep 16, 2002 | 01:32 AM
JumpyRoo's Avatar
Hey, J-Rat... how'd you do the pulley for that thing? I've been looking for a V pulley for this thing for a while.
Old Sep 16, 2002 | 03:21 AM
J-Rat's Avatar
Alcohol Fueled!
I got the pulley off of an old '67ish GM alternator. For some reason, it fit right on. Its the one peice style. My guess is, I got lucky. The only thing I had to machine was the spacer. From my experiment, I gathered that all GM pulleys will fit. You just gotta get one that wont grind the case. Plus I tried to custom grind a spacer, that was harder then I thought, so I just widened the orignal FC spacer with a Dremel. It fit like a champ..
Rat
Old Sep 16, 2002 | 03:22 AM
J-Rat's Avatar
Alcohol Fueled!
I can do a write up if you like..Honestly, it was a really easy conversion.
Old Sep 16, 2002 | 03:31 AM
NRA T2's Avatar
I neeeeeed to know hows it done
Old Sep 16, 2002 | 03:32 AM
NRA T2's Avatar
is it strait swap
Old Sep 16, 2002 | 10:05 AM
JumpyRoo's Avatar
A dremel... I tried drilling out the FC pulley and I couldn't get an even circle. Trying to get a spacer that doesn't grind the case is hard. I really don't know how the FD serpentine pulley did it, but it did. How do you tell?
Old Sep 16, 2002 | 04:39 PM
silverrotor's Avatar
You may want to swap out your old wires with new and bigger ones to maximize your Charging System now:
https://www.rx7club.com/forum/showth...hreadid=114675
