Thats my sons FD.. hes in the Air Force stationed in Japan.
We picked it up about 2yrs ago... traded his RX8 R3 for it.
Its gonna get my 2 rotor setup soon as ill be starting my 3 rotor swap now that im back form DGRR.
Started 20B engine placement. Im using Stevie's FD for mock-up. I couldnt bring myself to tear my car down yet and this just makes sense to use his for mock-up since its just sitting there.
Goal is to use the stock subframe and keep the engine back as far as possible while clearing the steering rack and trans tunnel.
Pics of where it sits for now..... still have some things to work out but I'm glad to be making progress.
Once I'm satisfied with engine placement 'I'll start the turbo manifold build.
A little less than 1/2" from the firewall lip.... that'll have to do....I have no interest in cutting on the car.
Almost tucked behind the strut towers..... but it's a big girl and that's about where she'll be.
Still trying out the Xcessive motor mounts with different height poly bushings to get placement dialed in.
Steve
looking good. Are you planning on running a dry sump or a custom pan? There's about a 0% chance the stock pan will clear the steering rack in that position. I have a few pictures in my build thread showing the alignment with the engine in almost that exact location.
i have a custom oil pan i bought from a buddy that had it in his 20B swapped FD w/stock subframe.
Its really low profile and should work.
I also have a Ronin Subframe that ill be sampling to see which setup i prefer for the motor positioning.
Yeah ive seen you pics and pics of many others setups to get ideas on how I want my motor placement.
Appreciate the input.
Hows your swap doing.. up and running again?
Steve
well, I'm curious to see where you land!
I hope everything is good with mine now. It's currently still in VT getting pretty much the entire car re-wired. I was planning on going up today to pick it up, but it's looking like it'll be another week or two before it's ready.
Glad to hear.. I'm looking forward to seeing an update in your thread!
Here's a pic of the oil pan.... the front of the pan is really low profile.
Steve
