T2 rear diff. question on FD
Old Feb 9, 2004 | 08:56 PM
0110-M-P's Avatar
Too Many Projects
I have read on current posts about the strength of the Turbo2 diff on the FD, but seach doesn't exactly work with this consider T2 is too short for search. So could anyone hook me up with any info on which parts are needed and/or some links to threads concerning this info.
M-P
Old Feb 9, 2004 | 09:17 PM
c00lduke's Avatar
I found alot of info when i was searching last week. But i tried now and just could seem to find much. Look for TII instead and you'll get info.
~Luke
Old Feb 9, 2004 | 09:44 PM
0110-M-P's Avatar
Too Many Projects
Wow im an idiot. Didn't even think to search TII. Thanks for the reminder. I found a bunch of stuff.
M-P
Old Feb 9, 2004 | 10:45 PM
93BlackFD's Avatar
built my own engine
you need a tII *87-88* differential
this is not the "chunk" per say, but the actually differential guts
they are a straightup swap with the FD differential, and you can use new bearings/spacers from an FD and it will require no shimming
meaning, you treat it just like your differential went bad in your rear end, only you swap the TII diff pack in with the FD spacers/bearings....you can't reuse the bearings/seals that you destroy essentially when you disassemble the rear end to get to the diff....so you have to use new ones
Old Feb 9, 2004 | 10:47 PM
Rhode_Dog's Avatar
\m/
didn't vosko do this swap?
Old Feb 9, 2004 | 10:51 PM
93BlackFD's Avatar
built my own engine
i don't think he did it himself, i think he has a mechanic, but he probably knows the details...not sure
Old Feb 10, 2004 | 12:12 AM
RX794's Avatar
NYC's Loudest FD
You guys should ask my good buddy Boostn7 the details, he's done this swap numerous times, I'll try to give him the heads up on this thread, so maybe he can answer your questions.
Old Feb 10, 2004 | 12:51 AM
jspecracer7's Avatar
1JZ powered
From: Where there's only two seasons, hot and wet! I love Okinawa
Jon had the swap performed, but had Judge Ito do it.
Old Feb 10, 2004 | 01:10 AM
GsrSol's Avatar
Z06 powered FD
I picked up my 87-88 TII diff from (Rich)Goodfellas and had my mechanic throw it in using everything else from the FD(bearings, ring and pinion, casing). Straight swap and you can feel the difference.
Old Feb 10, 2004 | 01:48 AM
Boostn7's Avatar
Did the 1st swap when my friend broke his FD diff many years ago. Decided to measure it when it was apart.....and since I had a spare T-II I tried it and it's been in there since then...over 5-6 years ago at least.
Just like "93BlachFD" mentioned.....treat it like you're simply replacing the guts using all the FD bearings and spacers....and drops right in. Just need to transfer FD ring and bearings(new) and slide it in.
My FD has seen at least 50 hard launches (ET streets and Nittos drags) this past year....Diff still holding well.
Good Luck
Old Feb 10, 2004 | 04:24 AM
Marcel Burkett's Avatar
If you are using a used T11 diff , you CAN use the same bearings , just don't mix up the outer races.
Old Feb 10, 2004 | 09:30 AM
vosko's Avatar
Just Call Me Terminator!
Good Luck
50 launches ??? oooh wait maybe you get kickedout right away for running 10's now
judge ito installed the diff but i was there helping
boostn7 was the first to do it. i was one of the first to do it with a BRAND NEW one though
Old Apr 26, 2004 | 09:25 AM
93BlackFD's Avatar
built my own engine
so you're recommending NEW bearings? i'm doing this this week, have ordered seals, do i need bearings as well?
Old Sep 15, 2005 | 06:55 PM
adictd2b00st's Avatar
boost > *
bringing this thread back since i'm doing the swap now............did u guys use the stock fd axles on this as well? i have all the "guts" swapped into the case, wanted to make sure before it goes back in
Old Sep 16, 2005 | 10:48 AM
boost > *
anybody?? diff is back in the car but the axles don't feel like they are going in as far as they should, almost like they are bottoming out
Old Sep 16, 2005 | 11:19 AM
HAI-TEK7's Avatar
you use the 3rd gen axles. im doing the same swap this coming week. Did you rebuild the S4 lsd unit?
Where can i get the clutch paks, ray @ malloy?
Old Sep 16, 2005 | 12:20 PM
boost > *
i didn't rebuild it , it was a lower mileage unit so i just dropped it in using new seals and bearings from malloy
Old Sep 16, 2005 | 02:36 PM
poss's Avatar
Slower Traffic Keep Right
You did get an S4 diff right?
https://www.rx7club.com/automotive-news-lounge-22/s4-clutch-typle-lsd-vs-s5-viscous-lsd-460891/
Old Sep 16, 2005 | 02:41 PM
cripsR6's Avatar
11.7@128
Is this a relatively easy project to do on your own? I have a brand new TII lsd and wouldnt mind saving some money (so I wont feel so bad buying the Rx7.com axles) if it is feasable.
Old Sep 16, 2005 | 09:30 PM
boost > *
thats definitly the problem........i have a ******* s5 diff
diabolical1
30
Jan 30, 2016 05:50 AM
Michael Mansour
Aug 18, 2015 03:13 AM
Marty RE
Aug 13, 2015 11:19 AM
