thread size/pitch of oil banjo feed on TII?
Old Feb 6, 2006 | 04:34 PM
tinvestor's Avatar
Anyone out there know the pitch and size of the banjo in the top of the front housing that feeds oil to the turbo? I need to order an annodized one.
Old Feb 6, 2006 | 05:03 PM
jenkin's Avatar
tinea incognito
Engine / Fuel / Coolant System / Lubrication System
S4 Turbo-to-Downpipe: 10mm x 1.5
N/A Exhaust Manifold: M10 x 1.25
Engine / Tranny Mounts:
(1) 14 mm head - Length = 145mm (5 5/8 in) (with head of bolt)135 mm (5 1/4 in) (from bottom of head of bolt to end of bolt). Nut on opposite end. FINE THREAD
(1) 14 mm head - Length = 100 mm (3 15/16 in) (with head of bolt) 90 mm (3 1/2 in) (from bottom of head of bolt to end of bolt). FINE THREAD
(2) 14 mm head - Length = 45 mm (1 3/4 in) (with head of bolt) 35 mm (1 3/8 in) (from bottom of head of bolt to end of bolt). FINE THREAD
(1) 14 mm head - Length = 40 mm (1 1/2 in) (with head of bolt) 30 mm (1 3/16 in) (from bottom of head of bolt to end of bolt). COURSE THREAD
Bottom Motor Mount: 12mm x 1.25 pitch
Pulsation Dampener Banjo Bolt: M12 x 1.25
OMP/MOP: N/A, 10mm x 1.0 bolts
TII, 10mm x 1.25
Oil Pan: M6 x 1.00
Oil Injectors: N/A, M10 x 1.0
TII, M10 x 1.25
Oil Injector Lines: NA: 10mm x 1.25
TII (some) : 10mm x 1.00
Oil Cooler: Front Cover is M16 x 1.5 — Rear of engine and both oil cooler are M18 x 1.5
Oil Feed Line Hole: front cover, 16mm x 1.5 thread pitch,
other three, 18mm x 1.5
Primary Fuel Rail Hold-Down (one of two choices): 10mm, M8 x 1.25 12mm, M10 x 1.25
Turbo Water Line Banjo Bolt: M16 x 1.5
Radiator Bleed and Drain Plugs: 12 x 1.25 x ~10 long
Turbine Housing to Downpipe (S5): M10 x 1.5 ::: The stud is 53mm long with a 10mm threaded end for the housing side and an 18mm threaded end of the downpipe side.
Steering
Steering Column Knucles: M8 x 1.25
P/S Rack Lines (two): M12 x 1.25
P/S Rack Lines (third, some models): M16 x 1.50
P/S Banjo Bolt: 10mm fine thread (go into the end of the steering link, from the pump)
Transmission/Clutch
S4 Shifter: M12 x 1.5
S5 Shifter: M10 x 1.25
Brake Caliper Bleeders: M8 x 1.0 and M7 x 1.0 respectively
Clutch Slaves: M8 x 1.0 or M7 x 1.0
Flywheel (wrench needed): 2 1/8" or 54mm
Wheels
Wheel Studs: M12 x 1.50
The stock sizes all have an offset of 40mm or 40 ET and are:
14 x 6 w/ 114.3 x 4 bolt pattern (Base, Luxury, 87.5-88 SE)
15 x 6 w/ 114.3 x 5 bolt pattern (GXL, Sport, GTU, 91 coupe)
15 x 6.5 w/ 114.3 x 5 bolt pattern (convertible)
16 x7 w/ 114.3 x 5 bolt pattern (Turbo, GTUs, Infini IV)
Other
Thermostat Housing: M6 x 1.0 , short bolts
Thermostat: M12 x 1.25
Skid Plate: 10mm flanges heads ::: probably a 6mm x 1.0
O2 Sensor: M18 x 1.50
Tie Rod Ends: M12 x 1.25
Front A Arm Mounting Bolts: M10 x 0.25 x 14mm head x 18cm length
Brake Rotor Brass Screws: 8mm x 1.25
Bolt Info
http://www.tech.plymouth.ac.uk/sme/desnotes/bolt.htm
http://www.roymech.co.uk/Useful_Tab.../Hex_Screws.htm
http://www.tech.plymouth.ac.uk/sme/desnotes/boltb.htm
Large bolt going through UIM into LIM : M8, course thread. Length is about 3-4 inches (thats a quote from Aaron )
Oh, and the engine/tranny bolt that is Course Thread : (1) 14 mm head - Length = 40 mm (1 1/2 in) (with head of bolt) 30 mm (1 3/16 in) (from bottom of head of bolt to end of bolt). COURSE THREAD : goes under the starter if IIRC.double check me on where the course thread bolt goes
Transmission mount, large bolt on bottom of crossmember: M12 x 1.25
Old Feb 6, 2006 | 05:05 PM
jenkin's Avatar
tinea incognito
does any of that help? didnt see the one you were looking for at first glance, but wtf do I know.....
Old Feb 6, 2006 | 05:17 PM
tinvestor's Avatar
not it
found that one a few times in my hour of searching
stickmantijuana
20B Forum
8
Aug 18, 2015 02:46 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
