T56 to automatic fd bell housing
Old Apr 16, 2011 | 02:30 PM
  #101
allrotor93's Avatar
I am using the 13B manual bellhousing and it fits perfect with an adaptor plate from summit drilled to match the t56. I am using a SPEC clutch.
Old Apr 16, 2011 | 02:33 PM
  #102
IronMdnX's Avatar
Glutton for Punishment
how did you make the starter and slave cylinder fit?
Old Apr 16, 2011 | 11:57 PM
  #103
t-von's Avatar
Rotor Head Extreme
Do you have pics and a part number?
Old Apr 18, 2011 | 11:16 AM
  #104
TitaniumCranium's Avatar
The Overattempter
Originally Posted by t-von
do you have pics and a part number?
+1
Old Apr 18, 2011 | 11:22 AM
  #105
GMO-RX7's Avatar
All Life
ahhh ****.
Old Apr 18, 2011 | 04:17 PM
  #106
rotorooter93fd's Avatar
YOUR TRIANGLE NIGHTMARE
Plus 2
Old Apr 20, 2011 | 09:41 AM
  #107
Blackadde///'s Avatar
20b GTX4294R MS Dry-Sump
RZMotorsports, any news?
Old Apr 20, 2011 | 01:05 PM
  #108
RZMotorsports's Avatar
1000hp Quest
Progress
I just purchased a automatic 93 bell-housing, to send it to the company that is making the SFI bell-housing so they can measure it and create the SFI one. I will keep you posted. The 1st one they made the circumference was to small so the flywheel didn't fit.
Old Apr 20, 2011 | 02:19 PM
  #109
The Overattempter
and the sfi housing is a direct bolt to the t56 correct?
Old Apr 21, 2011 | 10:46 AM
  #110
1000hp Quest
Sfi
yes it would be a direct bolt on to the T-56 magnum and to the 3 rotor or any engine that has an automatic back plate. so even the 2 rotor RE or 13Brew with automatic back plate would be able to use it.
Old Apr 25, 2011 | 10:00 PM
  #111
I wanted to share so that someone does not make the same mistake I did. the 20b bell housing is too deep and will not work. the 20b bell housing is one the right.
Old Jun 10, 2011 | 12:04 PM
  #112
ReZ311's Avatar
KM48 Burnout
So, what happened with these kits?
Old Jun 13, 2011 | 11:18 AM
  #113
1000hp Quest
kits
i should be receiving the new bellhousing prototype and i will post pics as soon as i get it.
Old Jun 21, 2011 | 01:05 PM
  #114
EllaMoto's Avatar
Im looking foward to it
Old Jun 22, 2011 | 07:55 AM
  #115
Sabora's Avatar
While it may bolt up rz if its like rooters problem then how would the t56 in a 20b still fit directly in if your making it for both fitment of 13br and 20b or is this an application that will work regardless as long as like the 20b its an automatic?
Old Jun 22, 2011 | 08:54 AM
  #116
jamaalsmith's Avatar
RZ, are you expecting the kit to be finished in the next couple of months, weeks, days?
Old Jun 22, 2011 | 11:31 AM
  #117
1000hp Quest
transmission
yea right now the bellhousing we are working on is to fit a automatic rear plate because the starter need to face forward. We are thinking of
developing one that utilize a rear facing starter but we want to finish the one we are working on.
Old Jun 26, 2011 | 04:19 PM
  #118
rcracer_tx's Avatar
Doing the Ricky Bobby
x2, Im interested. My fd tranny isn't in the best of shape and I'd like to upgrade to a t56 as long as I will be replacing the tranny anyways....
Old Jun 26, 2011 | 05:57 PM
  #119
Islander's Avatar
I thought u were working on trying to develop a kit for the 13b with a manual end.plate. thats where ur market will be. There are lots of 20b guys, but tons of 13b-rew guys. Keep us in mind. Extreme rotary also makes a adapter plate to mate the rew to the t56. It's like $800.
Old Jun 26, 2011 | 09:42 PM
  #120
allrotor93's Avatar
Just use a McLeod plate from summit and drill it to fit your 13b manual bell housing...that's what we did
Old Jun 26, 2011 | 09:55 PM
  #121
Slevin_FD's Avatar
pissin' on pistons
how do the input spines line up? Basically any other modifications necessary, and how does this place the gear shifter? Its for an FC so there would be some obvious differences. But maybe you happen to know.
Old Jun 26, 2011 | 10:11 PM
  #122
Islander's Avatar
^^^^^^I'm with him. Please explain. So many people have answers and solutions, but nothing detailed. Take a picture, send a memo, write a book. Just show us so we can do it. Instead we get... oh I just did it, its easy....... or just buy the parts from here its simple.... etc. Can we get details!
Part A: buy here.
Part b: insert there
Part c: remove
Step 1: find finger
Step 2: call hospital.
Step 3: car is done
Old Jun 27, 2011 | 10:07 AM
  #123
EllaMoto's Avatar
Part A: buy here.
Part c: remove
Step 1: find finger
Step 3: car is done
X2
Old Jun 27, 2011 | 12:00 PM
  #124
1000hp Quest
posting
Yea i found that is the best way to go, you get the best bang for your buck.
Old Jun 27, 2011 | 12:19 PM
  #125
1000hp Quest
kits
yes i will be working on developing a 13 manual kit, but my car has been out of commission since November because i don't have the bellhousing yet. So we decided to create the auto kit and then look into the manual, the problem we were running into was the placement towards the back on the t56 magnum it hit so we need some more R&D to get the starter to clear the transmission when its facing back. But we will work on that i love all my rotary family
