Your thoughts on this engine please (Pics)
Old Apr 22, 2003 | 04:48 PM
What do you guys think? I will follow up with more pics.
Petros
Old Apr 22, 2003 | 04:57 PM
Pic 2
(Rear housing)
mks's Avatar
mks
I think it's ported and had a clogged oil injector.
Seriously, what kind of comments are you looking for?
Old Apr 22, 2003 | 05:00 PM
Pic 3
(Front Housing)
Old Apr 22, 2003 | 05:03 PM
Pic 4
close up of rear
Old Apr 22, 2003 | 05:05 PM
Pic 5
close up of Front
Old Apr 22, 2003 | 05:08 PM
My bad. I should have given more info. This rebuild has 3000 miles on it and burned oil like a SOB. Actually put a quart in it every 50 to 100 miles. It smoked to high heaven when first started and once up to operating temperature the burning oil wasn't so visible, but if you let it idle for a while, it would start smoking again.
Petros
Old Apr 22, 2003 | 05:14 PM
DamonB's Avatar
I am no rebuild expert but looks like there is a lot of oil coming through the front rotor housing. Oil control rings on the rotors maybe?
Old Apr 22, 2003 | 05:26 PM
That is what I was told, I just wanted a second opinion. Does the rear rotor housing look normal?
Petros
Old Apr 22, 2003 | 05:32 PM
I was wondering if the rear housing looked normal. I know the front isn't, but I wanted a second opinion. This engine have given me alot of grief and I want to fix it ASAP.
Petros
Old Apr 22, 2003 | 05:49 PM
j9fd3s's Avatar
Community Builder
the rear rotor looks fine. on the front look closely at the rotor oil seals
mike
Old Apr 22, 2003 | 06:44 PM
powermalex's Avatar
Who did the rebuild?
Old Apr 23, 2003 | 12:01 AM
Why do you ask?
I would rather not say since I want to give them a chance to fix it and I would like to stay on good terms with them (unless they do this again). Many people will be very surprised to find out who built it. This engine has been smoking like chimney since day 1. Do we have a rotary engine builders forum I can link this post to?
Petros
Old Apr 23, 2003 | 12:24 AM
Mr rx-7 tt's Avatar
rotary sensei
I have been building rotaries for over 20 years.
The oil in the housing is not normal, neither is using 1 qt ever 50-100 miles. The problem could be a pinched oil ring seal (rotor) but the engine would have smoked from day one. It could also be a bad thermal pellit reinstalled. Either way the problem seems to be internal and the engine needs to be disassembled and repaired.I just noticed it smoked from day one...it's an oil "o"-ring that was pinched/torn on the rear rotor when the engine was assembled. ..
pm me if you would.
mazdaverx713b
48
Apr 21, 2016 06:45 AM
sYnth.
Aug 19, 2015 06:27 PM
