S5 TurboII 13.75 @ 104 - how?
Old Apr 13, 2003 | 07:12 PM
Barwick's Avatar
SCCA Rookie
I took the TurboII to Lapeer dragway today (about 65 degrees outside by the way), and ran quite a few times.. ran a few sub-14 times, best was 13.7 @ 104. I was shocked that I ran that fast.. I was hoping to run like 13.99 or something (previous best was 14.1 @ 100, before I put on the cone filter).
Basically all I've got is a custom turbo-back single exhaust straight through to a crappy "silencer" (can't even call it a muffler". And also a cone filter (no cold air box).
Also I should note, the DSV is acting up, so it runs to about 6 lbs and stays there.
SO.. basically I ran 13.7 @ 104 on 6 lbs boost. That's not too bad.
Oh, and I've pulled out some miscellaneous weight stuff (nothing that should get me THAT low though..)
I've pulled:
Spare tire
Sound "carpeting" from back
Rear trunk separator thing (that piece that makes it as if you have a real "trunk")
Stock exhaust (pretty heavy) to the custom single exhaust (not AS heavy).
All that though, I'm really curious now as to what I'm putting to the ground.
Old Apr 13, 2003 | 07:14 PM
Barwick's Avatar
SCCA Rookie
Oh and Jim (Raptor13x) ran like 15.8 in his '85 12A with no performance mods (except his exhaust is custom (CRAPPY) from the thermal reactor type thingey back to a pretty quiet muffler).
Old Apr 13, 2003 | 07:18 PM
J-Rat's Avatar
Alcohol Fueled!
Thats a GREAT time!
Old Apr 13, 2003 | 07:23 PM
rotary>piston's Avatar
I think you're just a good driver
Old Apr 13, 2003 | 07:48 PM
gsracer's Avatar
EIT
ran a 13.8@104
Old Apr 13, 2003 | 07:49 PM
gsracer's Avatar
EIT
ran a 13.8@104
heh great time
Old Apr 13, 2003 | 07:55 PM
Barwick's Avatar
SCCA Rookie
hm.. I need to gank off the air pump and I'd love to ditch the stock power steering rack, and put in an electric one or something..
Old Apr 13, 2003 | 08:01 PM
dr0x's Avatar
pei > caek
With 104 traps you could probably get below 13.5 with a hard launch.
Old Apr 13, 2003 | 08:16 PM
Rx-7Addict's Avatar
Rotary Powered
congrats..
that homebrewed turbo-back exhaust is prob. most of it. Probably added a good 50HP if not more
I would reccomend getting an SAFC and/or injectors
Very impressive times man!
Old Apr 13, 2003 | 09:46 PM
Barwick's Avatar
SCCA Rookie
yeah but it's only running 6 lbs boost.. that SHOULDN'T cause +50hp over stock.. something is WAY goofy in this car I think.. I'm gonna take it to the dyno I think, and also weigh it.
Old Apr 14, 2003 | 12:04 PM
ZachSpazz's Avatar
I wish I had a posse...
Well, isn't the engine in your car a J-Spec? Perhaps it's ported out or has some tricks done to the inside.
Old Apr 14, 2003 | 12:51 PM
ponykiller's Avatar
I definately agree with this.
Old Apr 14, 2003 | 02:43 PM
vosko's Avatar
Just Call Me Terminator!
very nice!
i ran 13.7 @ 100 MPH with my old TII @ 7psi with dp,mp,tid, act race clutch
Old Apr 14, 2003 | 02:53 PM
gsracer's Avatar
EIT
vosko,
I remember an old thread when you had the tII and you pulled a sub 2.0 60' time on one run. What tires were you on? I remember it was a street tire of some sort...
Old Apr 14, 2003 | 03:07 PM
vosko's Avatar
i did 1.92 60 FT on kumho ecta supra 712's on stock rims . i launch mad quick yo!
i am on the lookout for another 89-91 TII...
Old Apr 14, 2003 | 03:57 PM
SUPRAMAN
what are common 60ft times for modded TII's?
Old Apr 14, 2003 | 04:02 PM
vosko's Avatar
2.00 is excellent for any car on street tires.....
Old Apr 14, 2003 | 05:51 PM
RylAssassin's Avatar
isint stock times like 14.9 1/4. How in the hell did you cut a whole second off with just a exaust and intake?? Damn makes me wonder what i can pull. What is your car? s4? s5? stock engine? or Jspec as mentioned beofre
Old Apr 14, 2003 | 05:55 PM
SUPRAMAN
he said it was an s5 i want to know what i will run
Old Apr 14, 2003 | 05:59 PM
Damn! those damn s5's i bet thats why too, i dont think us s4 ppl can get that low with such basic mods, but im sure with the correct driver itll be real close
Old Apr 14, 2003 | 06:01 PM
gsracer's Avatar
EIT
err....see sig.
Old Apr 14, 2003 | 06:12 PM
Hey i wasent serious, i still cant think of a good reason to why its that low, but hey im thrilled either way...
Old Apr 14, 2003 | 06:33 PM
Barwick's Avatar
SCCA Rookie
That's what I was wondering, if it could be that.. it sounds really cool at idle (with the crappy exhaust).. although a little loud for my tastes..
It's kidna like badadum badadum badadum..
Old Apr 14, 2003 | 06:38 PM
von's Avatar
von
I bet he has a port job
Old Apr 14, 2003 | 06:42 PM
Barwick's Avatar
SCCA Rookie
Specs:
- White 1990 TurboII
- S5 J-spec engine imported from a guy in Canada ($1100 for engine and tranny SHIPPED.. good deal)
- Lightened, I'd guess maybe 100 lbs from stock, due to removal of stock exhaust (heavy) and put on the single turbo-back.
- Removed A/C & all stuff associated with it
- Removed sound deadening foam (not the hard stuff ON the metal, but the foam) from rear.
- Removed rear windshield wiper sprayer (wiper goes soon, doesn't work)
- Cone Filter
- That aformentioned ghetto 2.5" exhaust
- As far as I know it's a stock clutch, and I know it's stock flywheel
- Kumho Ecsta Supra 712's 225/50/R16 all around
- That's really about it.. I don't think the TB mod has been done or anything.. and like I said it runs to 6 lbs and really doesn't creep over that (the DSV is acting up, that's why it doesn't go to 8.. wonder what I'd run then if I had a MBC and it went up to 8 right away ) And it also bleeds off as I approach redline, going down to about 3 psi (I think) or so near redline.
New fuel filter & spark plugs, I dunno.. and Mobil 1 oil filter, heck I dunno.. and about a half a tank of gas.. 65 degree day.
By the way, the 60' times on those two 13.7 runs were like 2.091 and 2.065. This track has a real sticky starting line. A stock Z28 (stick I believe) ran like 13.5 there.
