Rate my setup
Old May 16, 2012 | 12:19 AM
JBF's Avatar
JBF
Thumbs up Rate my setup
So I bought my car already converted to single turbo.
However, it was an ebay build, minus the motor that is a pretty healthy street port with about 30k on the rebuild.
I have since removed the motor and will be upgrading everything that is ebay or crap.
Here is the list of mods (some I already purchased and some I will be getting):
1. Turblown TD61 ball bearing liquid cooled with 1.00 divided A/R with HKS style anti surge housing.
2. XSPower T4 manifold. I know it's still a cheap manifold but I can 't justify a $700 difference for a custom manifold just yet.
3. Synapse 50mm wastegate
4. Synapse BOV
5. Rotary Works 90mm TB
6. Full CJM fuel rail kit. (not sure if I want to run full parallel yet)
7. 550cc top feed primaries and 1650 top feed secondaries.
8. Either a defined vmount or a custom setup
9. PFC with single turbo converted harness.
10. 3" V-band DP with some kind of resonated midpipe and a Tanabe touring Medalion exhaust.
11. deleted OMP
12. AEM meth injection kit
13. ACT 6 puck sprung clutch
14. Power steering delete
15. A/C delete
16. 3 bar map sensor
17. Coil pack relocation (if that's possible)
18. Banzai oil pan brace
19. Himni motor mounts
20. Walboro 255
That's all I can think of off hand right now. My intentions of this build is a grip car since I live rather close to Willow Springs Raceway and I want to be able to have fun. I'm only listing engine power/reliability mods since this is what I'm attacking first in this build. Suspension and aero will be discussed in the appropriate subforums.
My power goals (shooting high) is 450whp but I would be happy with 400whp. I would like to stay around 15-16 psi on this setup and from the research I've done so far, my goals are feasible with this setup...
If anyone has any input, criticism, trash talk, etc, by all means chime in!!
Old May 16, 2012 | 01:38 AM
BLACK MAMBA's Avatar
FD Project
i would rather have Elliot at turblown build me a custom manifold for that nice turbo your getting and keep your stock Throttle body. you will want a nice flowing manifold for that turbo and xs power ebay is not a great match for the td61.
get a aeromotive stealth 340 lph instead of the walboro 255 lph, there are only 50.00 more than walboro.
Old May 16, 2012 | 01:44 AM
JBF's Avatar
JBF
What would be the issues with going with the rotary works TB? This is just out of curiosity.
Old May 16, 2012 | 02:14 AM
FD Project
some people complained that they leaked, i tested mine and it had a boost leak, i took it all apart and sealed it.
Old May 16, 2012 | 02:19 AM
JBF's Avatar
JBF
I'll pm the guy I bought it from and ask if he had any issues. If anything, I'll be hitting you up for what to seal and how to seal it
Old May 16, 2012 | 04:05 AM
mannykiller's Avatar
Garage Hero
^Is that you john?
Old May 16, 2012 | 04:09 AM
JBF's Avatar
JBF
Yessir!!
Old May 16, 2012 | 12:09 PM
XLR8's Avatar
Good advice here. A quality manifold is worth it, especially with track duties. For a 450whp goal, I would also would highly recommend a Stealth or Walbro 400.
1. Rotary Works TB - As mentioned, some have reported excessive leaking issues. If your car is going to be a track only car, then if there are no leaks, no issue with keeping it. However, for a street or dual purpose car, the OEM TB will work best. Considering your power goals, I would sell the Rotary Works TB and put the money towards a proper manifold. Some report transitional driving to be harder for single butterfly pieces of that size.
2. Fuel - I highly recommend Bosch EV14 high impedance injecotors. These not only plug directly in to the harness with no need for a resistor or driver, but their atomization is superior. They also respond better to higher duty cycles if more fuel is needed. I am using the 720/2000 combo. You may recognize the Injecor Dynamics as these. For realistically priced quality EV14's give www.injectorconnection.com . Ask for John. He knows exactly what sizes you need for different rails. You can also review this thread for fitment. You can of course pay twice the price for the magical amazing ID's injectors.... https://www.rx7club.com/showthread.p...ector+dynamics
3. Vmount - Great choice! By far the most superior IC/Rad setup. With track duties in mind, good ducting and a vented hood should be in order.
4. Oil cooler - Obviously not a part of the single setup, but you should definitely be running at the least OEM duals. Again, with a track car in mind, you may want to consider larger coolers.
5. Coil relocation - Good move. I relocated mine on the drivers side frame rail, just below the steering arm. This is out of the heat, and doesn't require different length spark plugs. I have never had issues with rain or anything like that, though my car has only been driven in the rain a few times. You can make a plate to mount them up, it's pretty easy.
6. Ceramic coating - I highly recommend this. Polishing manifolds is for the birds. If you want a function and form solution to heat then cermic coating it is. Cheramicrome is my choice. I had my upper, lower manifold, water pump housing, & filler neck. Exhaust manifold and downpipe is also a great choice. This stuff is trick. http://www.irperformance.com/service...ance-coatings/
Old May 16, 2012 | 01:12 PM
JBF's Avatar
JBF
Crap I didn't even mention oil coolers. Yes, I plan on running those. The car came with some terrible dual setup and I'm going to make a new dual 20-30 row setup trying to use some of the spare parts to try and keep costs down.
I will more than likely give Elliot a call next week to place an order on a manifold. I'll hang on to the TB for the time being and see if I like it or not. It doesn't take much to swap them out, so if I don't like it, no problem!
As for the ceramic coating, I do plan on doing that in the future. I'm just trying to find someone local to me to get it done.
Old May 16, 2012 | 01:29 PM
XLR8's Avatar
Sounds good.
That fuel injector link is www.fuelinjectorconnection.com
Old May 16, 2012 | 01:47 PM
Garage Hero
Nice man, you should give me a call or text i'll be over at the shop in a little bit.. maybe an hour or so. You should come by and check it out!
Old May 16, 2012 | 01:52 PM
JBF's Avatar
JBF
It'll have to be next time, Aaron. I have to start getting ready for work soon.
Old May 16, 2012 | 02:27 PM
Garage Hero
no prob brotha! i'll talk to you soon!
Old May 17, 2012 | 09:03 PM
Goreslinger's Avatar
RX7 Fan Boy
Sounds like a good set up, best of luck putting it together!
Old May 17, 2012 | 09:17 PM
JBF's Avatar
JBF
Thanks!
FFE fuel rail kit was ordered today!
Old May 18, 2012 | 10:38 AM
JBF's Avatar
JBF
Got a set of FFE rails on the way as well as some bosch ev14 725/2000 injectors!
Old May 18, 2012 | 10:46 AM
Garage Hero
you can get your an fittings through Aaron at FFE as well. Takes all the guess work out of it as well.. and wasted money on ordering extra fittings haha. Believe me.. i have a bunch of extra an fittings I never used because of it. sucks
Old May 24, 2012 | 02:33 PM
JBF's Avatar
JBF
Small update. I decided to have Elliot at Turblown make a manifold for me.
Old May 24, 2012 | 03:47 PM
Garage Hero
Elliot is a good dude, known him for a while now. He once drove from az-to san diego, to Lancaster to pick up a bumper I had for sale.. <lets just say he's one dedicated guy.
Old Jun 2, 2012 | 06:45 PM
boost16awd's Avatar
good setup it should get you decent numbers
Old Jul 4, 2012 | 05:23 PM
JBF's Avatar
JBF
I'm kind of on hold right now while I wait for Elliot to finish my manifold but I have since gotten the motor as clean as I feel necessary and sent a sponsorship off to AEM Electronics to try and run their methanol injection and their gauges.
We shall see!
Old Jul 5, 2012 | 01:57 AM
Turboeg1stgen's Avatar
Hope to see good numbers soon
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Wicked93gs
42
Oct 7, 2015 11:58 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
