What PSI should I start to spray?
Old May 15, 2012 | 12:25 PM
Tem120's Avatar
I have a na aquamist 2d which has a preprogrammed map , I have it setup so it starts spraying at around 5psi .
my max boost is 13psi .
now I've been reading and I did notice my a/f has richened from 11 to 10's after the install of my meth kit so I've been reading on leaning it out a little bit to make some more power instead of lose power .
I'm running windshield washer fluid .
which btw I think the ones htat work in colder temps are better correct?
but people keep telling me I have it set to early I should have it turn on much later . BUT I dont think they understand that my setup has a map its not just one of those on / off meth systems . rather then listen I've tried searching but failed at my criteria picking . so
I'm just wondering if anyone has any advice in this reguard.
as for the nozel.. I honestly dont know my kit was used , and had only one nozel . with no markings
Old May 19, 2012 | 06:46 AM
hiboost's Avatar
Serbian
I've heard, industrial methanol is better choice... Some people made more power with it vs windshield fluid. Search about it.
Old May 19, 2012 | 04:40 PM
tom94RX-7's Avatar
5 psi is good I think
Old May 19, 2012 | 11:55 PM
BDC's Avatar
BDC
BDC Motorsports
+1. Earlier in boost the better IMO but don't go too heavy on it. Can reduce EGT's too much if using too much and can lower boost threshold.
B
Old May 30, 2012 | 03:31 PM
Tem120's Avatar
B
THe max my system will spurt out with the biggest nozzle is only 300 CC's I've left it at 5 psi and it seems to work fine there .
Old Jun 5, 2012 | 07:53 PM
G's 3rd Gen's Avatar
Mine activates at 5 psi. Look into the relay that incorporates the windshield washer tank to flow with the aquamist pump. Its called the primary pump activater. Very easy added install. It will push you up yo 500-600 cc's. Added another nozzle as well. Goodfellas and I are using it with great results. G
Old Jul 22, 2012 | 04:34 PM
FD3S2005's Avatar
SideWayZ The Only Way
i have mine kick on at 8psi
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
