Just completed the Non-Seq Turbo Conversion.
Old Jul 25, 2002 | 01:52 AM
legendr35's Avatar
Poor-man's method of course =) The installation took a tad longer than I thought since I had trouble taking out the TCA, but after that everything else was cake. (THANKS DONT_BE_A_RIKKI for the great and easy to follow info on your site)
The car has more lag on the low end, but not as bad as I thought. It use to start spooling around 2800K but now it starts around 3400-3500K. The mid to high end power feels a bit stronger, however, I do kinda miss the kick on the butt feeling when the 2nd turbo comes on. But most importantly, NO MORE BOOST SPIKE! Now my manual boost controller works great and I can boost more without worrying about spiking. Although, I still hit fuel cut, do they make a FCD for FDs???
Old Jul 25, 2002 | 04:58 AM
jspecracer7's Avatar
1JZ powered
Re: Just completed the Non-Seq Turbo Conversion.
Yeah...it's called the Power FC
Old Jul 25, 2002 | 01:13 PM
turbojeff's Avatar
Do it right, do it once
Stock twins spool quite a bit before 2800 rpm when working properly. They actually start to spool around 1700-2000rpm.
All non-seq conversions are the "poor man's method" IMHO. If you want to ditch the seq twins the "right way" get a single.
Anyway I'm glad your happy.
Jeff
Old Jul 25, 2002 | 02:57 PM
legendr35's Avatar
Re: Re: Just completed the Non-Seq Turbo Conversion.
Any other method beside the PowerFC? That unit is out of my price range. Thanks
Old Jul 25, 2002 | 03:12 PM
7-sins's Avatar
thats not paint....
Re: Re: Re: Just completed the Non-Seq Turbo Conversion.
That unit is tops!!!!!! Smooths out the car sooooo much. I recommend saving up for it. $980 is a great deal for it from canman. I could have spend the money in tons of other places but I am glad it went there. Unless you plan on going with a exotic setup later down the road, you might want to hold off for a Haltec.
Old Jul 25, 2002 | 03:20 PM
legendr35's Avatar
Re: Re: Re: Re: Just completed the Non-Seq Turbo Conversion.
It sounds really tempting, but I need another set of turbos soon, which I will be buying next (i have 132K on my stockers ) they still boost 10-12PSI!! =)
Old Jul 25, 2002 | 08:12 PM
is it usa version though? from cannman aka jason ?
Old Jul 25, 2002 | 09:21 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
you need to get some sort of ecu whether it be m2, pettit, gforce or pfc cuz you'll be hitting fuel cut no matter what and fuel cut is bad.
Old Jul 25, 2002 | 10:26 PM
kwikrx7's Avatar
Jeff
Why? Single's are expensive and full boost comes on at 3500-5000 rpms depending so you have even more boost lag. You just haven't ridden in the right non-seq FD
Old Jul 25, 2002 | 10:28 PM
1JZ powered
It'll work just fine. You won't have to pull any pins or anything.
Old Sep 11, 2002 | 09:51 PM
fd3virgin's Avatar
where did you get the pfc??? is $980 w/ the commander??? also. thanks
Old Sep 11, 2002 | 10:33 PM
7-sins's Avatar
thats not paint....
http://www.jt-imports.com had them listed at $980 but since as changed to $1200. I got mine from a Forum group buy... $1050.
Old Sep 12, 2002 | 12:05 AM
Batmobile's Avatar
Dude...HKS makes an FCD..its about $130...I have one...I'll show...negro...you gots to call me about these questions!!
Old Sep 12, 2002 | 01:25 AM
7-sins's Avatar
thats not paint....
The PFC is a nice unit though.... if i'm up in MD with Rikki and them you have to hang out and I will show you what it's like. It clears up a lot of crappy issues with the stock system.
Th0m4s
Feb 26, 2019 02:04 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
