How much for parts to rebuild motor?
approximitaley how much just for parts does it cost?And is it easier or harder than rebuilding a 4 cylinder?, would me and a couple friends(who are mechanics) be able to perform this task in a weekend?
Also, what companies sell the non-flip up headlight kit?
1JZ powered
Re: How much for parts to rebuild motor?
from what i've read here, and not personal experience,
rebuilding a rotary is easier than that of a piston motor. because a piston motor has more clearance issues, and you normally need to bore/hone the cylinder walls more.
On a rotary, if the rotors and housings are still useable, u can resuse them, and then just change all the seals, put it back together.
Do a search on "removing motor with tranny" there is a great write up there.
1JZ powered
Heedlessone
288
Sep 16, 2018 07:22 PM
