woohoo! i think i've figured out my dellorto!
Old Jul 24, 2002 | 02:17 PM
rotorhead's Avatar
Thumbs up woohoo! i think i've figured out my dellorto!
after a year of futzing around with jets, and not knowing what the heck i was doing, i think my del is setup and running smooth! thanks to brad p, rxcetera, badassrx-7, tigger09, and anyone else i might have annoyed with all my questions. and one huge thankyou to anyone who helped put together www.gruntled.com , probably the best dellorto info i've seen on the web.
greg
Old Jul 24, 2002 | 04:11 PM
Kill No Cone's Avatar
Ok, so what is your set up? Are you running it on a stock 12A or something else?
Old Jul 25, 2002 | 02:55 PM
rotorhead's Avatar
i'm running a stock 12a with a pacesetter exhaust(not worth a darn). i used the 12a stock settings: 230 main fuel, 230 air correction, 7850.4 idle jet holder, and 72? idle jet. go to www.gruntled.com . they have dellorto settings for 12 stock, 12a streetported, and 13b stock. the only difference between mine and will's (on the site) settings is that i have my idle jets backed waaaay out. like around 5 turns out. i know this means i should rejet one size larger on the main fuel, but it's running better than it ever has before. the stock settings will get you close though. before, i had 235 mains, 210 air correct, 80 idle fuel jets, and 7850.8 idle jet holder. it ran super rich, but idled well. i had lots of stuttering from 4k up at any constant throttle position. now, no stuttering, smooth all the way up, still a tad weak down low, hence the idle jets being backed out. at normal 2.5 turns out, it would nearly die when going into 1st gear from a standstill.
Old Jul 25, 2002 | 02:56 PM
rx-7girl's Avatar
post whore queen
im proud of ya buddy boy.....i think
Old Jul 25, 2002 | 03:30 PM
RXcetera's Avatar
EliteHardcoreCannuckSquad
Good job! Sorry I didnt reply to your last pm... I'll do that right now. Glad to hear you got it dialed in .
Coochas
44
Nov 5, 2019 11:08 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
eplusz
15
Oct 7, 2015 04:04 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
