anyone using RPM rails and ID injectors?
Old Mar 26, 2012 | 11:11 AM
misterstyx69's Avatar
Retired Moderator, RIP
Arrow anyone using RPM rails and ID injectors?
I am thinking on the RPM rails for an S5 TII application,and I need to know if the 1000 and 2000 ID injectors are gonna fit without issue,.
anyone use this setup?.
Thanks.STYX.
Old Mar 26, 2012 | 11:57 AM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
Risingrpm?
I got the rails, but currently not installed. I got ID 1000 installed on the stock rails right now. As far as I know, rpm rails were made to fit stock injector size which is 11mm tops. For ID injectors you will need the 11mm adaptor and the denso style cushion
Old Mar 30, 2012 | 09:48 PM
Ya sorry Black Knight.I meant to put Rising but I got lazy!
.I got the S4 rails and RC's right now on a s4 lower,and I would like to put the "normal" S5 lower back on the Keg( Keg is s5)..wanna put the RisingRpm rail and the ID's on that.
Anyways I guess what I can do is try the fitment of the ID's with a stock rail,.If they fit that then I know the RisingRpm Rails are gonna work..Right?
Old May 11, 2012 | 12:41 AM
I got the rails,and I got the injectors.
RisingRPM gives you 4mm spacers for the S5 TII secondary rail that you put in between the rail and the manifold.
Test fitting the ID injectors on a lower manifold I am going to put on, it looks like you do NOT need the spacers on the secondary rail...
I haven't torn into the engine yet,But I will update with any other info as I go.
Cheers Guys.
13
Jan 9, 2018 11:19 AM
Skeese
65
Mar 28, 2017 03:30 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
