Microtech Microtech Shutting down laptop software
Old Mar 17, 2012 | 09:53 PM
TurboMazdaSpeed's Avatar
1.3L piston eater
Long story short looking at a T2 fully built with a Microtech LT-10s ,
Symptoms
When laptop plugged in to microtech and tuning w/ microtech program , when getting in the higher boost levels / RPM (over 16 PSI / 7000rpm +++ ) The microtech shuts down the program on the laptop. There is nothing wrong with the laptop or software since this does not happen with any other microtechs the tuner tunes.
This is what was described to me, i have not seen it happen but it is preventing the car from getting a full proper tune and the owner thinks its a ground problem.
Has anyone had this happen before and what could it be? Looking to possibly buy this car soon so input would be great.
Thanks
PS... There is also 1 slightly leaky secondary injector, could this be part of the problem?
Cheers
-Collin
Old Mar 18, 2012 | 09:49 AM
Aaron Cake's Avatar
Engine, Not Motor
Are you saying that the software is crashing?
If that's the case, just to be thorough, I'd try it with another laptop.
Old Mar 22, 2012 | 11:35 PM
1.3L piston eater
Im picking up the car on the weekend, ill go over all of the microtech wiring then will bring it to tuner to see if the problems cleared up. Quite sure he has a different laptop by now lol
Old Mar 23, 2012 | 12:42 AM
bumpstart's Avatar
talking head
you need to use resistive plugs and leads, rfi is corrupting the serial connection
Old Mar 24, 2012 | 01:23 AM
1.3L piston eater
So what your basically saying is the serial - usb cord they could have potentially been using was low quality? That could make sense also and save me lots of time on checking the wiring.. Its a maybe for getting that car right now.
Old Mar 24, 2012 | 06:36 AM
bumpstart's Avatar
talking head
possibly-
and/ or
some plug and lead combos ( and alts and fans and wiring ground loop issues )
can sing so hard they corrupt the 12V and internal 5v bus for tps on the ecu
and you just have to change back the plugs to FD or rx8 resistive types ( and get silicon suppressed leads )
check first what plugs the car is running
,, if they are bike plugs ( like eg or egv ) or the racing trust or NGK types , then they are most likely culprit
Old Apr 14, 2012 | 12:54 AM
1.3L piston eater
possibly-
and/ or
Thanks for the info man! Sorry for the late reply been busy working, i fixed the leaky injector so far and re did some grounds.. The car has no e fan, stock prop, I will check on the plugs tomorrow if its nice out
squirrels
Sep 1, 2024 09:52 AM
Andrew7dg
Aug 6, 2017 01:41 PM
93FD510
Oct 1, 2015 02:00 PM
rattlehead
Sep 25, 2015 10:55 PM
