Rats Nest Removal, Need help with remaining vacuum lines
Old Feb 24, 2012 | 06:49 AM
asiandude15's Avatar
WA Rats Nest Removal, Need help with remaining vacuum lines
I got block off plates and installed them. There are a few spots where lines are coming from that I need to sort out. I just need to know if it is ok if I plug them or do I need to connect them somewhere like for example there are nipples on the intake manifold. The motor is a S4 TII USDM.
1. From the oil filler neck
2. The line from the Charcoal Canister
3. After the Oil Filler neck on the center plate there is an nipple.
Old Feb 24, 2012 | 06:54 AM
Molotovman's Avatar
Ban Peak
Do a little searching. you will find what you need.
Heres a link to the stock diagram. https://www.rx7club.com/attachment.p...1&d=1242616856
There are many threads on S4 TII emissions removal, just search.
Old Feb 24, 2012 | 10:41 AM
TIIFC3S's Avatar
Freshly Built Streetport
Here's what I did:
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/double-rats-nest-removal-twin-scroll-addition-913213/
If you're taking out all of the emissions controls (rats nest), then there's no need for the charcoal canister. Get rid of it.
Here's a thread about some ideas for the oil filler neck nipples:
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/crankcase-vent-906841/
Old Feb 27, 2012 | 01:57 AM
barnett87rx7's Avatar
lite rotary = easy push
this is for a s4 tII
Attached Thumbnails Rats Nest Removal, Need help with remaining vacuum lines-s4-turbo-emissions-removal.jpg
Old Apr 12, 2018 | 11:10 PM
Campbell97's Avatar
Anyone have vacuum diagram delete for an s4 N/A
streetlegal?
Mar 17, 2022 02:46 PM
dkwasherexd
May 27, 2017 04:51 AM
12abridgeport
Aug 17, 2015 06:28 PM
pzr2
Aug 15, 2015 08:29 PM
