RX-8 13B-RE conversion!
Old 03-18-12, 03:31 PM
  #76
ChrisRX8PR's Avatar
Finished tacking the manifold together and threw it on the engine with the turbo just to see it...now I will drop the engine back in the car and make sure everything fits properly before I weld all the seams together...pics speak for words
Cheers.
Chris
Old 03-18-12, 09:47 PM
  #77
A.K.A. LuisGT
1973rx3's Avatar
Extremely nice! Excellent work!!!
Old 03-19-12, 06:30 PM
  #78
ChrisRX8PR's Avatar
Got the engine in the car again to check manifold fitment, clears everything perfectly. The Downpipe area is tight for 4"...might need to cut or hammer a lip in the engine bay to get it through. Now just need to pull things out again and weld the manifold shut.
On another note, I placed the Alternator as in the pictures and realized I could make a rod so that its mounted like that instead of the other way...only thing I will have to do is make a tensioner wheel so the belt clears the base for the A/C tensioner.
Cheers
Chris
p.s. started to get excited when I saw the turbo in there...lol
Old 03-19-12, 06:55 PM
  #79
cfamilyfix's Avatar
Sweet!!!
Old 03-20-12, 06:24 PM
  #80
ChrisRX8PR's Avatar
Sewed her up!
Now just to open up two holes for the wastegates and done deal!
Cheers!
Old 03-21-12, 03:02 PM
  #81
The Silent but Deadly Mod
Roen's Avatar
Originally Posted by ChrisRX8PR
Yes I am using two ECU's in my car. The stock ECU to keep all accessories and other things happy and a Stand Alone controlling engine function. The OEM ECU will receive engine sensor input but will have 0 control of it.
All ancillary accessories will work properly.
I am using the Renesis Front cover on the BRE engine.
Chris
Which specific standalone ECU if you would be so kind?
Old 03-21-12, 03:43 PM
  #82
ChrisRX8PR's Avatar
The goal is to end up using a Haltech Sprint RE but I might start with one of the Microtechs I have around here just to get it up and running before spending on the Haltech.
Chris
Old 03-21-12, 05:49 PM
  #83
John Huijben's Avatar
Exhaust looks pretty good. I assume you took some 90 degree premade bends and cut them to size? How did you cut them? Grinder? I'm currently also fabricating a header, but it's tricky getting the bends cut precicely right. I'm using a much thinner gauge as you so I'll need to get the gaps as small as possible if I want to get it welded nicely.
Old 03-21-12, 05:55 PM
  #84
ChrisRX8PR's Avatar
I used 2" Schedule 10 304 SS pipe both straight and 90Deg bends. I cut everything using an industrial bandsaw I have at the shop for cutting Solid Bar to be used in the CNC machines. If you are using thinner gauge I would recommend cutting things a bit longer (approx 1/8") and then sanding them to fit with a large band sander...I couldn't do that because of the thicker gauge.
Cheers!
Chris
Old 03-22-12, 02:27 PM
  #85
ChrisRX8PR's Avatar
Started working on the down pipe after receiving the 4" v-Bands...
Cheers
Old 03-22-12, 03:24 PM
  #86
ChrisRX8PR's Avatar
Tial Q just came in!
Old 03-22-12, 04:23 PM
  #87
stevensimon's Avatar
what size piping/tubing is your exhaust mani?
Old 03-22-12, 05:02 PM
  #88
ChrisRX8PR's Avatar
2" Schedule 10 304 SS...You can find it at McMaster Carr.
Chris
Old 03-22-12, 05:04 PM
  #89
ChrisRX8PR's Avatar
One step closer to having the DP finished....
Cheers
Old 03-22-12, 08:42 PM
  #90
ChrisRX8PR's Avatar
Had to modify the piece I had already "fabbed" once I fit it in the car again to make sure everything fit properly. All the DP should need now is a straight shot into the existing exhaust and full welding...
Cheers
Chris
Old 03-23-12, 11:59 AM
  #91
gmpaul's Avatar
Hey Nice project but if you don't mind me asking which do you perfer RX-8 Or RX7?!? I personally cant stand the RX8 and think that 1: yeah mazda put out another rotary series but its verry round IMO Just The Body Style Itself is IDK gross lol but then again thats My opinion.
Old 03-23-12, 12:43 PM
  #92
speedrx8er's Avatar
Oh my, I did not realize how much space that 4" downpipe will take up..
You have any scraps I can have or borrow for visual placements?
Old 03-23-12, 12:58 PM
  #93
ChrisRX8PR's Avatar
I like them both...they are very different cars. The handling is great on both but one is a minimalist 2 seater with 0 compromises as a sport car. The other has amenities and space. If I were going to have only one car it would be RX-8, GPS, heated seats, everything's electric, 4 seats, traction/stability control, etc etc etc make for a very nice daily driver in comparison. I already have the RX-8, like the amenities and its only about 200-250lb heavier than an FD so it still goes great with a rotary. I also intend to drive it all the time and living in MN its the better option at least for me.
Cheers
Chris
Old 03-23-12, 12:59 PM
  #94
ChrisRX8PR's Avatar
Yes you can have the left overs...Im not planning on building two...lol
Chris
Old 03-23-12, 01:20 PM
  #95
speedrx8er's Avatar
Chris
Awesome, thanks
Old 03-23-12, 06:16 PM
  #96
ChrisRX8PR's Avatar
Awesome, thanks
Don't forget your turbo exits to 5" on the hot side so you will need a reducer.
Chris
Old 03-23-12, 06:18 PM
  #97
ChrisRX8PR's Avatar
Updated list of todo's
Machine front cover - STARTED
Weld front cover
Front cover oil line
Machine front pulley spacer
Driver engine mount finish
Pass engine mount finish
Finish LIM (welding, holes etc) - STARTED
Drill UIM bolt hole
Make/Weld Throttle body adapter to UIM - STARTED
Make RX-8 Throttle body flange
Oil filter Pedestal (machine, relocate, whatever)
Modify Water Pump Outlet - STARTED
Oil pan and pickup
Alternator Adapter
Custom Alternator Tensioner
Relocate OEM ECU to Firewall
Install Wastegates
Make Downpipe - STARTED
Make Wastegate dump
Fuel rail mod
Make/Modify Fuel lines
Make Turbo Oil lines
Make Radiator cover plate
Water reservoir
Intercooler mount
Cut Intercooler piping
Weld Intercooler piping
Weld BOV
Replace exhaust sleeves
Machine engine for studs/Dowels
Make Ignition Bracket
Old 03-23-12, 07:02 PM
  #98
Always Learning
atheadwins's Avatar
Nice looking work! This is wild!
I hope to learn to weld in the near future, it looks awesome being able to make your own exhaust manifold. Not to mention the $$ savings.
Old 03-24-12, 05:00 AM
  #99
Uncontrollable drifter
dznutzuk's Avatar
Here's something you might need for #9 on your list. Just make sure to double check the dimensions.
File Type: zip
Old 03-24-12, 10:11 AM
  #100
ChrisRX8PR's Avatar
Oh wow, thanks Man! I was going to have to draw those to be able to program them, Now I can just work on CAM side of things...
I recognized the oil pedestal one and the other ones seems like its the bolt pattern from the BRE mani with a round hole for my throttle...am I correct?
Thanks a million!
Chris
Quick Reply: RX-8 13B-RE conversion!
