my '79 project....
Old Jul 22, 2002 | 11:53 PM
Sublime's Avatar
Talking my '79 project....
just to keep it short, heres a list of plans....
body kit(havent decided yet)
turbo(...17psi...)
posibly a 3rotor
new paint(the broonzish from the caddy CTS)
17" enkei wheels. 245/35R17 tires....probally.
and uhh....oh ya!! new suspension...weeee!!!!!
ill keep you updated....
Old Jul 22, 2002 | 11:56 PM
Keaponlaffen's Avatar
hmmmm... digging everything but the tires..... too low pro, not enough flex for cornering, especially with the turbo or 3-rotor.
Jeff
Old Jul 23, 2002 | 12:01 AM
Sublime's Avatar
i was thinking of 245/40R16, too, probally the 16's, but if i were to get the 17s they would have to be 35 to fit right and not jake my car way off the ground
Old Jul 23, 2002 | 12:02 AM
Sublime's Avatar
*jack
Old Jul 23, 2002 | 12:25 AM
Manntis's Avatar
add to cart
I'm running 205/50 R16s and it corners better than stock. Avoiding flex in cornering is the whole point of low profile tires; otherwise the tire folds under the rim and cleaves itself.
245s would be too wide to fit. The 205s on 38mm offset rims have only 1/8" between the wheel and the strut spring, and the fenders had to be sleightly modified to allow tire clearance on the outside to prevent scuffing over bumps.
anything larger than 16" on an RX7 and you get a far less comfy ride, less protection for the rims, etc.
Old Jul 23, 2002 | 12:41 AM
hmmm, I always thought you wanted a bit of tire flex for cornering, for extra traction....
Jeff
Old Jul 23, 2002 | 11:59 AM
jeremy's Avatar
male stripper
thats for straight line acceleration. more sidewall allows flex which inturn the sagged sidewall places more tire on the pavement. 35 is asking for trouble though. rim dings, harsh ride, etc.
Old Jul 23, 2002 | 02:03 PM
Manntis's Avatar
add to cart
Sidewall flex in a regular tire does place a larger contact patch on the road on a conventional, rounded tire but in a corner the sidewall can end up under the wheel rim and has no traction surface - you're just risking shredding a tire.
The straight shoulders of low profiles already place the traction surfaces of the tire on the road and the stiffness places the cornering geometry where it belongs, in the suspension.
Old Jul 23, 2002 | 04:01 PM
Directfreak's Avatar
I am a Jeeper Now.
Re: my '79 project....
turbo(...17psi...)
posibly a 3rotor
WOW. You're only 19 Years old and you're getting a 3 Rotor in a 79?!
Congrats!
Charlie Paul Graeser III
Aug 6, 2013 11:45 AM
olyrx7
Dec 18, 2010 06:02 PM
