rotating guages....just read....
Old Jul 22, 2002 | 08:23 PM
R Xplicit's Avatar
in porsches, they are equipped with factory VDO guages. my friend has a pair of 993's one turbo and one n/a. He has rotated the tach/speedo counter colckwise so that during higher speeds, the needles are more in the 12-o'clock position. hence, they are easier to read, and it helps for visibility in cornering....i have driven and ridden, so it does work. just wondering if i can do the same to mine. i know the guages LOOK individual, but are they moveable at all.....i have never checked....
-louis
Old Jul 22, 2002 | 09:12 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Not that I can figure out. I've had mine out several times.
Old Jul 22, 2002 | 09:20 PM
R Xplicit's Avatar
cool, thanks. are they all one behind the "panel of faces" or are they individually screwed in? cause if they are seperate there might be a way//
Old Jul 22, 2002 | 09:23 PM
Fd3BOOST's Avatar
They are all seperate. I can post pics of the stock ones out if you like???
Old Jul 23, 2002 | 08:36 AM
Hyperite's Avatar
Vagina Junction
No, it is one panel of guages and the cover has circular cutouts to make it look like they are individual.
Unless you scrap the panel and put in all aftermarket guages, rotation is not possible
~Tom
Old Jul 23, 2002 | 11:11 AM
Flybye's Avatar
It's never fast enough...
I know exactly what you are talking about. MY friend has a NA 85 911 and he also has some of this gauges turned like that.
I've also seen the gauge cluster out, and there really wouldn't be a way to turn them like that
Old Jul 23, 2002 | 03:29 PM
Fd3BOOST's Avatar
~Tom
You are not talking about a Fd apperenty. I'm confused now. I am saying that the guage faces are seperate round pieces. Which they are. Did I miss understand the question???
Old Jul 23, 2002 | 03:35 PM
Node's Avatar
he meant turning the entire gauges themselves.
turning just the gauge faces would be funny
Old Jul 23, 2002 | 04:53 PM
Fd3BOOST's Avatar
Yea I figured that I was getting it wrong.
I'm a donkey... Hee Haaaa
Old Jul 23, 2002 | 11:48 PM
potatobbq's Avatar
i think this might actually be possible (maybe)... the tach/speedo gauge faces are each held in place by four small rubber "fastener things"... i don't know what else to call them. but anyways, i think it would be possible to rotate them and just glue them in place and then recalibrate the needles to read the correct rpm/speed.
BLUE TII
Sep 26, 2015 10:12 PM
Devon Murray
Sep 25, 2015 09:41 AM
dradon03
Sep 18, 2015 05:57 AM
