Engine Fusebox Wiring
Old Feb 10, 2012 | 05:51 PM
stuwk1's Avatar
Does anyone have a picture or can explain to me where each wire that goes onto the bolts on the fuse box come from?.
Old Feb 10, 2012 | 07:39 PM
HAILERS2's Avatar
The wire on the front side comes from the batterys positive post.
The one one the rear ties into the cable from the alternator output plus it's spliced into the wire that feeds the ignition switch and also feeds the two circuit breakers on the top row of the interior fuse box.
It might have been easier to say the one on the rear goes to the alternator, which it does, but it also has the other wires spliced to it that I described above.
And the fuse box can be installed 180* out and you don't wanna do that becaue that will result in you installing the wrong wires on the wrong side of the engine bay fuse box.
Old Feb 10, 2012 | 08:41 PM
stuwk1's Avatar
When you say front you mean the top photo would be the front of the box? and the bottom the rear? thanks for the info.
Old Feb 10, 2012 | 09:55 PM
HAILERS2's Avatar
The fuse box sits sideways when mounted in the car............the EGI fuses on a series four car would be on the inboard end of the box .
Soooo if you mount it like that you have a front and a rear side of the box. Make sense?
Series four or five? I described a series four engine bay fuse box which has two EGI fuses on the inboard end of the box.
Old Feb 10, 2012 | 10:45 PM
stuwk1's Avatar
series four got it now thanks!
streetlegal?
Mar 17, 2022 02:46 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
