stress releaving
Old Feb 9, 2012 | 12:47 PM
rurounixblade's Avatar
stress releaving
has anyone cryofreezed there rotary. I wanted to ask before I send mine out. If so did you also have to remachine the iron surfaces and rotors?
Old Feb 11, 2012 | 02:58 PM
so i guess im gonna be the first
Old Feb 11, 2012 | 03:22 PM
Derekcat's Avatar
Rotary Zealot!
Err.. Why? That supposed to do?
Old Feb 11, 2012 | 10:45 PM
w0ppe's Avatar
CC of L-Squared Shots
So you plan on freezing it for the next 10 years and breaking it out when there is a cure for gas mileage?
Old Feb 11, 2012 | 10:59 PM
its a stress relive the block and i did it on my honda engine and i wanted to know if anyone has done it with a rotary block and if so would i have to remachine the surfaces
Old Feb 12, 2012 | 01:20 AM
fcs4manila's Avatar
S4 Love
Never heard of you verse. But it makes me want to read up more about it.
Old Feb 12, 2012 | 05:27 AM
Derekcat's Avatar
Rotary Zealot!
Ok... What stress are you trying to relieve? I can't think of anything that that would help...
Old Feb 12, 2012 | 07:29 AM
beefhole's Avatar
Boosted. I got BLOWN!!!
Cryo treated apex seals have been done before. Don't know about other engine parts though.
Old Feb 12, 2012 | 11:06 AM
i wanted to relieve the rotors and e shaft mainly because they are the parts that are gonna see the most heat.
Old Feb 12, 2012 | 01:25 PM
RW-7's Avatar
Moderating the Trochoid
Are you referring to doing the entire engine?
I do not recall if Kryo treating aluminum has the same effects as treating steel.
Atkins Rotary has kryo treated engine parts available. Mostly seals.
I had a few parts done by a local diesel shop the were able to do my e-shaft, stationary gears and counterweights for not to much. Might be something to look into.
Old Feb 12, 2012 | 02:52 PM
did you have to resurface your e-shaft once the process was done?
Old Feb 12, 2012 | 07:04 PM
RW-7's Avatar
I plan on checking the runout and having the rotating assembly balanced prior to assembly.
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
BLK 93
Sep 28, 2015 01:45 PM
