Does the ECU have a dedicated Water Temp sensor?
Old Feb 7, 2012 | 07:39 PM
Tem120's Avatar
Well my temp gauge goes to HOT , asoon as I open the ignition * not start *
after I start the car . the power FC commander tells me the degrees in Celsius started at 22 degrees and I shut the car off at 88C ,
so I mean thats working ..
BUT the gauge on the gauge cluster seems to be grounded somewhere and read HOT as high as it can go the whole time .
not I'm trying to figure out if there is a short ..
or if the sensor is bad ..
but unless the power FC has its own dedicated temp sensor .. then that temp sensor cant be bad since it was working with the Power FC.. and the short is in the front harness .
Old Feb 7, 2012 | 08:51 PM
to_slow's Avatar
Yes the ECU gets the temp off a different temp sensor than the gauge. The gunge sensor is under the Oil pedestal.. Hope that helps
Old Feb 7, 2012 | 08:52 PM
BLACK MAMBA's Avatar
FD Project
water temp sensor for dash gauge is on driver side rear iron, below oil filter.
water temp sensor for PFC is behind water pump housing, so power fc has it own dedicated sensor.
Old Feb 7, 2012 | 08:59 PM
Tem120's Avatar
yes thanks alot both of you guys. I guess I need to source a new sensor .
Old Feb 7, 2012 | 10:58 PM
JonnyQuestions's Avatar
yeah its behind the thermostat housing on top. Green connector. Thats for ecu sensor. The gauge is a one wire sensor. Id check to see if you have wiring problems first before replacing sensor
Old Feb 8, 2012 | 08:37 AM
TwinCharged RX7's Avatar
Built Not Bought
Top Answer: 1
What are the 2 sensors for on the back of the water pump housing, one is the ecu temp, but what is the other?
Old Feb 8, 2012 | 09:30 AM
RENESISFD's Avatar
Wastegate John
^ Fan Thermoswitch. You are talking about the sensor with one wire correct?
John
Old Feb 8, 2012 | 10:24 AM
Built Not Bought
Top Answer: 1
Yeah, they are right next to eachother on the back of the housing. I'm just trying to figure out what I can get rid of.
Snoopy FD
Dec 8, 2015 01:45 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
