engine swap soon
Old Feb 6, 2012 | 06:24 PM
FC3Sreaver's Avatar
engine swap soon
my engine's coolant seal has given away and i was going to put my spare engine in (both are series 4 engines). the other engine was carb. and i want to swap over the fuel injection. while doing this swap i was going to get rid of the emissions i dont really need so i was going to ask if anyone knew exactly what i need and what to remove. ive searched through the threads but couldnt find anything detailed. i would also like to know of some things that i could replace other than gaskets and the vacuum lines (that i will actually keep). i need help and i was planning on doing this soon so i would like to say thank you in advanced.
Old Feb 6, 2012 | 06:40 PM
sharingan 19's Avatar
Rotary Revolutionary
Please actually search. Use "emissions removal".
Thanx.
Old Feb 6, 2012 | 06:46 PM
dwb87's Avatar
This is my social media.
S4 N/A Emissions Removal
S4 TII Emissions Removal
Keep the Bypass Air Control Valve (BACV a.k.a. BAC). I wouldn't mess too much with the throttle body. The "throttle body mod" is pretty much useless.
Quality emissions block off plates -> Rising RPM Block Off Plates
Old Feb 7, 2012 | 12:55 PM
TX_RX's Avatar
I hate to thread jack FC3S Reaver, but I like the look of that Rising RPM stuff. I only see TII though, do you know if they have anything for an N/A? I know most of the block off plates will fit both, but not all.
Old Feb 8, 2012 | 11:45 PM
FC3Sreaver's Avatar
yeah i didnt see any either. but i looked on banzai-racing and they have the block off plates for cheap. i have not ordered from them before so i would like to know if they are good too.
Old Feb 8, 2012 | 11:47 PM
FC3Sreaver's Avatar
thank you for the links..... i really did search but i dont know if there is a difference if i search when im logged in or not. but is there anything else i should look out for when im swapping the stuff over? other than the whole leaky pulsation dampener issue alot of people have?
Old Feb 9, 2012 | 12:22 AM
Keep the Bypass Air Control Valve (BACV a.k.a. BAC). I wouldn't mess too much with the throttle body. The "throttle body mod" is pretty much useless on an n/a.
Fixed.
It makes no difference if you are logged in, it only makes a difference if you use the proper search terms.
If you have access to the pd go ahead and replace it w/ a banjo bolt (search "banjo bolt"). There are no documented failures of any sort due to lack of a pd. There are numerous documented engine fires resulting directly from pd failures. Case closed.
Old Feb 9, 2012 | 12:43 AM
dwb87's Avatar
The reason I posted both N/A and TII emissions removal links, was because you never stated whether it was N/A or Turbo... Which now I realize that you did point out that one engine was carbureted. I assume it was not a carbureted turbo engine. So, I apologize for the TII block-off link.
What is it that you mean when you say, "but is there anything else i should look out for when im swapping the stuff over?" ? What are you "swapping over" when removing emissions? Things to swap from an EFI engine to a carbureted engine?
Here are some links that contain some N/A block-off plates...
Pineapple Racing: Block-off Plates
Mazda Trix: Block-off Plates
Old Feb 9, 2012 | 12:54 AM
dwb87's Avatar
Originally Posted by sharingan 19
Fixed.
I originally was going say that... The reason I didn't say N/A is because it's completely debatable. The "TB mod" is a thing of the past. You'll be better off just not even messing with the throttle body... Whether it be N/A or turbo. I chose to go with a general statement.
Old Feb 9, 2012 | 05:42 AM
Banzai-Racing's Avatar
Rotary Specialists
Block off plates http://banzai-racing.com/store/FC_block_off_plates.html
Old Feb 9, 2012 | 05:47 AM
dwb87's Avatar
Originally Posted by Banzai-Racing
^ I was looking for these on your site earlier... Or this specific link, I should say. I searched and searched. Banzai Racing block-off plates seem to be the most reasonably priced.
Old Feb 9, 2012 | 01:06 PM
FC3Sreaver's Avatar
well the engine i will taking out is just a stock n/a but the one i am putting in has a racing beat intake manifold and had a holley carb on it. i dont want the carb setup anymore so i was going to just swap over the intake manifold and basically all of the stuff for the fuel injected motor to the other one. they both are series 4 n/a blocks its just the one that i will be putting in has the intake manifold for a carb. i had that setup on my old car and i like the fuel injection alot more. it more consistent and alot better on gas .
Old Feb 9, 2012 | 01:23 PM
FC3Sreaver's Avatar
Fixed.
i looked it up and if it ends up that the pd is leaky i will do this fix..... its alot cheaper than getting a new pd
Azevedo
26
Mar 1, 2019 09:19 PM
maikelc
Aug 24, 2015 11:04 AM
elfking
Aug 19, 2015 09:48 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
