ABS Pump Leaking, can it be fixed? Pics
Old Feb 4, 2012 | 03:58 PM
ppritchard's Avatar
93 Touring
FL ABS Pump Leaking, can it be fixed? Pics
Been losing break fluid, now finding that it is a leak at the ABS pump area.
Fluid is pooling around the middle, if you can see it.
Seems to be leaking more lately, so it's more than a drip.
Can it be repaired or does it require replacing the unit?
Searched, but only found one '03 thread with similar issue.
Thanks for any help
Old Feb 4, 2012 | 04:09 PM
ppritchard's Avatar
93 Touring
The FSM says you can "inspect" and "repair or replace" parts-- but I haven't found anything about how to check what.
Old Feb 4, 2012 | 04:12 PM
jmirage04's Avatar
93 E85
I'm having the same problem. I bought a used one off eBay and that one leaked too! I'm thinking of doing abs delete kit. From what I've read they can't be rebuilt
Old Feb 4, 2012 | 04:31 PM
DaleClark's Avatar
RX-7 Bad Ass
There are O-rings in the pump that's supposedly fixable. But, really, leaky ABS pumps on FD's are VERY uncommon.
Buy a known-good ABS pump off someone on the forum, install, and be done with it.
The ABS delete kit is one way to go, but for a street car ABS is a VERY good thing and a significant safety feature.
Dale
Old Dec 6, 2012 | 12:43 PM
Perry9394's Avatar
I have the exact same problem on my 04 FD, after changing the left rear caliper, the pump started leaking, I guess it's just old.
I m looking for a used pump too, what did u do to urs?
Old Dec 6, 2012 | 02:06 PM
ThekidintheFD's Avatar
Ill sell you my abs pump if youd like. Its on my car and is great working shape. off a 93. pm me.
Old Dec 6, 2012 | 02:22 PM
FearNoPiston's Avatar
FREAK ALL OUT!!!
you should clean it and trace the leak, it may just be the crush sleeves. mine were leaking and I replaced those and no more leak.
-Chance
Old Dec 6, 2012 | 02:51 PM
Fritz Flynn's Avatar
All out Track Freak!
I have some good ABS pumps just PM me if you need one
Old Dec 12, 2012 | 02:47 PM
ppritchard's Avatar
93 Touring
I got hold of a low mileage one and that was that. Check with Fritz.
Old Dec 13, 2012 | 08:13 AM
Thanks
I had a couple of people PM me for pics etc..... and I have 3 available at this time.
I haven't had time to get the pictures but I'll post those when I have a chance.
Old Dec 16, 2012 | 02:30 PM
Perry9394's Avatar
pm sent, Fritz.
pls keep me posted for pix, mileage and price shipped to WA 98281, thx.
Old Dec 17, 2012 | 12:24 AM
MSTHTD1's Avatar
Strictly Rotary
Veteran: Navy
Yes the only fix for that leak is to contact Fritz same happened to mine, and if it goes unnoticed for to long the ABS fluid will start eating away at the paint & undercoating. As mentioned before I bought a low mileage unit from Fritz.
Old Dec 17, 2012 | 09:43 AM
Originally Posted by Perry9394
pm sent, Fritz.
emailed a pic
Thanks for the referral
ABS pump came from a car that currently has 72k miles on it but it was removed at least 5k miles ago so safely say no more than 68k miles on the pump. $135 for this pump pictured.
I have 3 other pumps that look equally as good and one that's REALLY NICE with under 10k miles of use but it's pricey $250
Attached Thumbnails ABS Pump Leaking, can it be fixed? Pics-zzzzzzzzzzzzzz-abs-cayman-parts-049.jpg   ABS Pump Leaking, can it be fixed? Pics-zzzzzzzzzzzzzz-abs-cayman-parts-048.jpg
Old Dec 10, 2016 | 08:02 PM
Buzzman's Avatar
Hey Fritz...
Do you have anymore ABS pumps ???
Kyo
Apr 13, 2019 09:24 AM
tsmith94FD
Aug 16, 2015 05:41 PM
