Leaking Coolant Help!!
Old Feb 3, 2012 | 05:27 PM
tysrex93's Avatar
Unhappy Leaking Coolant Help!!
K so I went into the garage today cause it was +4 out and installed a lil fc commander holder thing and on my way out I noticed a lil pool of liquid on the ground. On futher inspection it was the coolant and it had kind of like drips off the radiator on both sides..... It was really cold here like -40 ish and then warmed up could have the coolant froze and then burst something? I have pics I will post. sigh this is not what I needed outta her as im preparing her for spring
Old Feb 5, 2012 | 10:16 PM
tysrex93's Avatar
K, I topped up coolant, and ran the car for about 30 mins and temps never went above 91 c and nothing dripped onto the ground. I inspected all hoses and there was no sign of leaking from the hoses, but the rad itself had some coolant on it, and once it reached 90 c u could see a bit of steam coming from the top left of the rad and smell coolant.....Time to replace Rad? Forgot to say, it is a 93 rx7.
Attached Thumbnails Leaking Coolant Help!!-399891_10150538021961464_511631463_9343069_1341129680_n.jpg   Leaking Coolant Help!!-396708_10150538004671464_511631463_9343042_1256113553_n.jpg
Old Feb 5, 2012 | 10:28 PM
misterstyx69's Avatar
Retired Moderator, RIP
If you can't find any leaks then I would be suspecting that the coolant itself is not up to par.
I would be checking with a hydromometer(?) to see the Freeze point of the coolant.
It sounds like it is not a 50/50 Mix..and is old.
OH..State your CAR SERIES.
Old Feb 6, 2012 | 02:07 AM
tysrex93's Avatar
I mixed it myself 50-50 nappa green its only a year old was plannin on doing a flush, but I might just replace the rad now.
it's a 1993 RHD
Old Feb 6, 2012 | 10:40 PM
gracer7-rx7's Avatar
needs more track time
3rd Gen FAQ thread has a couple of excellent coolant threads where you can learn more about the coolant system
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
You'll want to "rent" a coolant system pressure tester from your local Autozone or auto parts store to pressurize the system and look for leaks.
Old Feb 7, 2012 | 11:32 AM
lynchX's Avatar
Play nice rotary brothers
a new radiator will solve the problem.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
sinistersam
Sep 13, 2015 07:17 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
