Wire Harness Check (out of car)
Old Jan 31, 2012 | 04:48 AM
jdonnell's Avatar
Just wondering the best way to check an emission harness before I install it? It is a replacement harness. Is checking wire resistance the way to go? All clips are intact except 2 which I can crimp back on.
Old Jan 31, 2012 | 10:17 AM
satch's Avatar
That's a good way.
Old Jan 31, 2012 | 10:24 AM
RotaryEvolution's Avatar
Sharp Claws
resistance check is about all you can do. unfortunately it won't always point out an issue such as frayed insulation where 2 wires are rubbing together causing cross continuity, that can be time consuming to check for. well maybe not too bad but it is a good idea to check as well, just doubles the check out time.
Old Jan 31, 2012 | 05:36 PM
jdonnell's Avatar
Thanks for the inputs. I may unravel some as far as practical to take a peak on wire condition. I noticed my 90 emission harness has the blue/orange air bag wires. The replacement is supposedly from an 88' w/no airbag. I reckon I can swap the airbag harness portion over?
Old Jan 31, 2012 | 09:30 PM
misterstyx69's Avatar
Retired Moderator, RIP
Have fun with changing harnesses that are NOT the same series!
(you should know that by now!)
Old Feb 1, 2012 | 03:54 AM
jdonnell's Avatar
Its the emission harness and all connectors are the same. I did ask the forum if they were interchangeable before I bought it. Looks good.
Old Feb 5, 2012 | 07:00 PM
jdonnell's Avatar
Checking continuity of an emission harness I find this wire which I think is for the 02 sensor, but I cut the protective sleeve and see the wire is much thicker gauge than my previous harness 02. And I don't see the wire come out the other end (ECU end) that is the same size. Anyone recognize what this is?
Attached Thumbnails Wire Harness Check (out of car)-dscn1480.jpg   Wire Harness Check (out of car)-dscn1481.jpg
Old Feb 6, 2012 | 12:45 AM
HAILERS2's Avatar
S4 and S5 EM harnesses are not the same and not even close to being the same.
An 88 EM harness will not plug into a series five ECU nor mate with the Front harness.
If your new harness does connect to the series five front harness and ECU..........then it ain't a series four 1988 EM harness but a series five EM harness.
Old Feb 6, 2012 | 04:03 AM
jdonnell's Avatar
Must be a S5 harness then. Injector clips fit and everything 99% looks the same. ECU plugs in as well.
I went back and checked and its from a 89' with no air bag. Oops, sorry I had my info wrong.
Old Feb 6, 2012 | 06:13 AM
shocker003's Avatar
it looks like o2. check resistance between that wire and pin 2c on the harness
Old Feb 6, 2012 | 06:08 PM
jdonnell's Avatar
Thanks! Saved me time alot of time. 02 it was.
Old Feb 7, 2012 | 06:58 PM
jdonnell's Avatar
Should I be getting any continuity between these 3 grounds? Thanks.
1) Vacuum bracket ground
2) Fuel injector ground
3) Ground at ECU plug
Attached Thumbnails Wire Harness Check (out of car)-dscn1482.jpg   Wire Harness Check (out of car)-dscn1483.jpg   Wire Harness Check (out of car)-dscn1484.jpg
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
