Oil Pan Sealer
Oil Pan Sealer
Anyone have opinions on the best oil pan sealers to use WITH a gasket? I bought this one minute gasket Right Stuff gray that some friend recommended, but I never heard of it. After reading the label it sounds to good to be true.
That should work just fine. Grey is generally for higher torque applications, it is also more rigid(still kind of soft though) than black rtv once it has fully set.
On FC oil pans I have had good luck with using a gasket and a bead of black rtv on both sides.
honda bond works, mazda has some stuff too 8527-77-739 is the part number. black or grey silicon will also work.
the KEY IMPORTANT PART. is to make sure that the surfaces are clean, and that they get 24hours to dry/cure before it sees oil.
also you should throw out the gasket, it won't work as well as just silicon sealer.
Trending Topics
I ended up changing my mind and going with the Honda-bond. I never used it before, but I figured Honda-bond would be about as good as you can get. Everything I bought with Honda's name on it before last a long long time.
Why is it no good to use the gasket? I never had problems with gaskets on other parts of the engine.
mazda never used a gasket.
but the issue is with overtorquing the bolts, it has a tendency to rip the gasket at the holes which then causes leaks. the only reason to use a gasket is if the pan is warped from several rebuilds.
You're right. I put a single bead looping around the bolt holes towards inside the engine. It was a good thick bead. some squished out the bolt holes when i torqued it down. It should be a good seal.
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
