fuel management system????????
Old Jan 26, 2012 | 05:59 AM
zoil's Avatar
MD fuel management system????????
as most know i have a 91 vert n/a. i am now planning on a turbo need to know the best fuel management to get? i would like a power fc but couldnt find one for my year on apexi website. im sure theres is a few different ones i can get. haltech seem a bit pricy. any help will be great
Old Jan 26, 2012 | 07:54 AM
Group's Avatar
Eh, good enough.
The Power FC for the FC stopped existing for a while now, and only was available for the turbo models.
Many people here have tried megasquirt with nice results. I believe 'aaroncake' actually used it for his 6 port turbo.
Rtek is another solution, but it's just a stock ECU upgrade, so it does have it's limits.
You're best bet would be to check out the Engine Management Forum
www.rx7club.com/forumdisplay.php?f=37
Old Jan 26, 2012 | 09:56 AM
Arecibo's Avatar
MD Fuel
I would consider microtech and AEM
Hey I have some friends in the area with some knowledge
I am currently adapting a 93tt engine to my 84 GAL
Hyattsville>
Old Jan 26, 2012 | 05:38 PM
dwb87's Avatar
This is my social media.
Haltech is well worth the money.
If you are dead set on the A'PEXi Power FC, Banzai Racing sells an adapter so that you can use the 93-95 FD version of the Power FC. It would be cheapest to buy a used Power FC here on the forum, but you are sure to get an undamaged unit from Banzai.
Banzai sells the FD3S Power FC for $1,075.00
They sell their S5 adapter kit for $315.00
Banzai Racing: S5 PFC adapter and A'PEXi Power FC
Be sure to check out other engine management systems in the > Engine Management Forum
There are so many EMS options. Read up! And weigh out the pros and cons. If there's something you don't understand, perform a search... If you do not find your answer, post a thread. Good luck!
Old Jan 28, 2012 | 10:41 AM
Aaron Cake's Avatar
Engine, Not Motor
My car runs a Microtech LT8s.
Haltechs aren't really pricey at all. Price out a Motec. The Haltech Sprint RE is a good basic ECU. If you are DIY type, then the Megasquirt is a good option.
The ECU is a small part of the project though. Keep in mind that if you intend to turbocharge the NA engine, you're going to have to fabricate most of the system. Also the S5 NA compression of 9.7:1 is about the limit of reliability in a forced induction applications.
Old Jan 28, 2012 | 12:45 PM
zoil's Avatar
i understand the compression issuse. i know there's going to be some fabrication involved. iv read and looked into some of the FMS still haven't found the right one for me. money not a problem don't want to have to get another a few years form now for future upgrades.
as far as the n/a motor i want to get it set up and when it blows then just rebuild it because my car runs just fine right now with only 122k on it. not saying this is the best way to go also thought about just buying a T2 and dropping it in.
Old Jan 29, 2012 | 02:29 AM
dwb87's Avatar
Not saying that this is necessarily the "best" way to go... But the TII swap would be cheaper. If money is not an issue, you can go either route. You'd also better have a GREAT learning curve. Aaron Cake KNOWS the "turboing an N/A route"...
Aaron Cake's (Almost) Complete Guide To Turbocharging The Naturally Aspirated Second Generation RX-7
Old Jan 29, 2012 | 10:41 AM
Aaron Cake's Avatar
Engine, Not Motor
I don't get it...Money is not a problem but a Haltech is expensive?
What defines the EMS as the "right" one for you? Haltechs have been standard on the RX-7 since the mid 90s. Megasquirt has been used for about 10 years. Microtech has been around about as long as Haltech (though Microtech ECUs are very primitive and I don't recommend them for a street car).
Do that. Just buy a TII engine and drivetrain, prep it, rebuild it, do whatever needs to be done. Then put aside a week to perform the swap.
Old Jan 30, 2012 | 10:15 AM
zoil's Avatar
Moneys not a problem. But if I don't have to spend the Monet for haltech then why do it. But as it seems haltech is the way to go. So ill buy it when I'm Ready for it
Queppa
Nov 18, 2024 03:47 AM
Snoopy FD
Dec 8, 2015 01:45 PM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
82streetracer
Aug 23, 2015 09:28 AM
