Haltech innovate LC-1 into PS2k; setup and install/interface questions
Old Jan 25, 2012 | 10:43 PM
stevensimon's Avatar
hello all. installing an innovate LC-1 wideband and it has two options for outputs.
The default analog outputs are as follows: Analog output one is 1.1V = 14 AFR and .1V = 15 AFR, and Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39
AFR.
which output should i tie into the haltech?im assuming the 'Analog output two" is correct. is there a setting i have to change so it will read the wideband correctly or is the stock wideband voltage range correct?
thanks for your input.
Old Jan 26, 2012 | 01:10 AM
C. Ludwig's Avatar
www.lms-efi.com
Use output two. Easiest to leave the Innovate output calibration alone (though it can be changed) and just change the Haltech input to match. Enter the values above in the wideband input calibration in the Haltech software and you're on your way.
Old Jan 26, 2012 | 09:45 AM
awesome thanks!
jdayau
Nov 29, 2019 12:11 AM
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
apooch
Sep 4, 2015 10:27 AM
