widebody question about the plastic inner fender...?
Old Jan 22, 2012 | 01:30 PM
MoePwr's Avatar
Ballin!
I doubt im going to post the pic right sorry is i do it wrong. Heres my concern. I will be purchasing widebody fenders and i currently have a fd shell.... my question is what parts from this diagram am i not going to need... if any. i just dont want to purchase something i dont necessarily need. much help is great needed and appreciated!
Old Jan 22, 2012 | 01:39 PM
Athanon's Avatar
BTR RANCID
do you have an actual picture of the car depending on what you have already will obviously depend on what you need. when you say shell thats a vague discription.
if you post a pic i will try and help you out as i have done the bsport wide body on my car at one point but eventually took it off after a distructive encounter with a curb.
Old Jan 22, 2012 | 01:46 PM
MoePwr's Avatar
Ballin!
all i have is frame. theres no fenders no bolts no plastic. but yeah let me get you a pic
https://picasaweb.google.com/1148560...56609453376322
Old Jan 22, 2012 | 02:18 PM
felix_is_alive's Avatar
pic does not work
depending on the kit , you might need to modify the fender liner to fit under the fender , or you will have a gap
Old Jan 22, 2012 | 02:34 PM
MoePwr's Avatar
Ballin!
That's what I'm wondering... Do I need fender liner and everything in that diagram
Old Jan 22, 2012 | 02:58 PM
I don't know whta you have at the moment ,but even if you get the new fender liner ,you will Still need to modify it to fit the widend fender
Old Jan 22, 2012 | 03:50 PM
MoePwr's Avatar
Ballin!
How do you modify it?
Old Jan 23, 2012 | 12:42 AM
IWINULUZ's Avatar
I dont see you being able to modify it being that on alot of after market fenders they barely have big enough IF ANY inside tabs to connect fender liner to, also remember if you are stretching the fender liner that will bring it closer to your tire, and more than likely will scrub. good luck
Old Jan 23, 2012 | 10:23 AM
MoePwr's Avatar
Ballin!
thanks for the info. i just would like to know whether or not its needed because im ordering widebody fenders with my tax return and am going to need all new mounting requirements as well. just wondering what i need
Old Jan 23, 2012 | 10:33 AM
Crap I still think the burnout kit car is in my shop , and the body shop guy was here a few days ago , I can see if I can get pictures
Old Jan 23, 2012 | 10:40 AM
MoePwr's Avatar
Ballin!
that would be great
Old Jan 24, 2012 | 01:09 PM
Athanon's Avatar
BTR RANCID
tools: measuring tape, tin snips, a drill, a rivit gun and a little inginuity should get it done but depending on what you have on the car. if it were me i would pull the wheel apron out of a dually ford truck rear end and modify to fit the front end. it doesnt have to be an intricate piece of work it just has to protect what isnt being protected by the factory fender liner. you could easily find these trucks at any junk yard or pulla part
if im not mistaken i think they are held on by heavy duty staples on the rear end of the truck. you could also use thr front end wheel liner to make the job easier. this is what i did with my bsport wide body before i demolished it
Old Jan 24, 2012 | 05:00 PM
MoePwr's Avatar
Ballin!
awesome thanks for the great information man. much appreciated.
rx7jocke
72
Jun 17, 2016 03:48 AM
Nosferatu
Sep 5, 2015 02:13 PM
Apoc3D
Sep 5, 2015 10:24 AM
