Won't start after radio installation. 89 second gen
Old Jan 17, 2012 | 07:03 AM
Iniquity's Avatar
CA Won't start after radio installation. 89 second gen
Hi Everyone, would first like to say hello and thanks in advance for any help I receive. I could not find any other threads that could help me out so Im going to post one.
So to get this started, I am a new RX7 owner. first rotary and I love it. d any major issues. However yesterday I decided to install an aftermarket stereo because my car did not have a stereo. So I spliced all the wires from the car and stereo that I needed. Did not touch anything else. Only the small bundle for the stereo speakers and power etc. I got the stereo working fine. Came out a bit later to leave and car would not start. Can hear the ignition click but does not turn over at all. Headlights also seem to shut off when trying to turn the key. And if It helps, when I pushed the hazard lights button it made a weird noise. So I uninstalled the stereo. made sure everything was out it was prior. made sure there were no wires touching eachother or anything else. checked fuses. There was a blown 10 fuse so replaced it. Still nothing. Lights seemed to dim down more and more after trying a couple times. Changed the battery and headlights came back on. all system lights are on like normal then when attempting to start it headlights go out and car wont turn over. Just hear the click. Headlights also wont go back on after they go out that first time right away but idk if its anything I did they came back on a couple times.
My conclusion. Could I have messed something up seriously just from a stereo installation? If any wires happened to cause a problem. It got dark out so I had to stop troubleshooting. Hope for some feedback on the issue.
Old Jan 17, 2012 | 09:13 AM
satch's Avatar
Is the different battery new or old? What voltage does it have? Which fuse did you blow? You say the engine doesn't turn over or does it turn over but not start? You say the ignition clicks. Does this click occur w/key to on or start?
Old Jan 17, 2012 | 01:45 PM
Iniquity's Avatar
Not sure which fuse because it does not have the cover that shows what is what. And the battery was from my friends car. And it clicks when turning to start.
Old Jan 17, 2012 | 03:41 PM
Iniquity's Avatar
It doesn't crank.
Old Jan 17, 2012 | 04:01 PM
Th0m4s's Avatar
The battery is bad. Try to recharge it or get a new one.
Old Jan 17, 2012 | 06:48 PM
satch's Avatar
Does the car have the factory alarm or not?
Old Jan 18, 2012 | 05:16 AM
Iniquity's Avatar
I got my car starting. I found some issues with the terminal to the battery. Guess it was just a coinsidence that it happened after I installed the stereo. But the terminal isnt seating properly and causing the issue because when I really adjust it then car starts fine. Going to fix it soon but thankfully it isnt anything too serious.
Thanks guys for the feedback
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Im faster
Aug 19, 2015 02:57 PM
